Hi everyone
I’m new to here , but I’m hoping someone can help me who has knowledge or advice. Ok here goes, I’ve just purchased a Peugeot Boxer 1.9td 2001 camper with the XUD 9UTF engine. I’ve just changed the timing belt and finding it difficult to find torque settings. I’ve done as per a manual I’ve purchased the bottom crankshaft bolt to 30lbft followed by 60 degree and loctite on the thread. For some reason a couple of days later the bolt has worked loose, so I’m hoping someone might have the correct settings.
Torque setting
- x 6955
Re: Torque setting
Sorry, but I personally don't have the specific data you need for this vehicle, being as it is quite early and the paper-based info wasn't all transferred over to the later systems.
- x 1930
Re: Torque setting
Could the torque figure have been 30 Nm not lbft?
- x 1056
perrye
- (Donor 2026)
- x 10
Re: Torque setting
Haynes says 40 Nm+60 degrees
Barney00731102012
Re: Torque setting
Just wanted to thank everyone who took the time to reply to my post, in regards to the crankshaft bolt torque setting, it’s much appreciated.
