D'ohh, my C5 X7 has just failed the MOT. Part numbers for rear discs and pads please.
Both outer CV gaiters have also failed. What's the OE offering? Or should I go for a universal gaiter that can be pulled over the joint without dismantling?
C5 X7 Driveshaft Gaiters
- x 1938
Reason: Split off from Parts thread for discussion here
- x 6956
Discs
(1) OEM Disc Kit, part: 4249C1, £141.43
Cheaper Alternative, part: 1687773280, £76.08
Pads
(2) Brake Pad Rear Kit, part: 1647894180, £114.79
Gaiter (3) Wheel Side Gaiter, part: 3293C8, £77.68
Axle Side Gaiter, part: 3287C9, £49.10
Pads
- x 1056
They are Cheaper, easier to fit & in most cases better quality than the originals. No brainer really.Paul-R wrote: 16 Feb 2024, 18:30 Or should I go for a universal gaiter that can be pulled over the joint without dismantling?
- x 1938
How easy are they to fit? Especially if you don't have one of the powered f***y stretchers?
- x 1938
Re: C5 X7 Driveshaft Gaiters
Answered my own question. I've found that you can get a plastic cone for a tenner.
- x 1485
Some X7s are fitted with shafts where the CV joint doesn't come off, so a stretch boot is very preferable to pulling the shaft and dismantling it to allow the boot to fitted from the other end!
Sloppysod
- x 392
Have they split or just "popped" off the joint?, mine "Pop" off the hub occasionally, I think it's when turning the steering on full lock when the suspension has no weight on it, for instance on high or on axle stands.Paul-R wrote: 17 Feb 2024, 20:32 Answered my own question. I've found that you can get a plastic cone for a tenner.
Stu
- x 1938
I don't know, it's been too cold to look. The gaiter on the left has popped off before when the original clip broke off and disappeared. I fixed it when I did the suspension ram last year so it may actually be a split this time. They are 11 years old now!
