Thanks very much for the links. Unfortunately though, when I plug in the USB the car tells me that the update is not compatible with the hardware in the car, which I find rather confusing.GiveMeABreak wrote: 31 Jan 2024, 18:42Firmware 44.07.05.22_NAC-r0NikolajPedersen wrote: 31 Jan 2024, 11:46 I'm having the same thing with my ë-Berlingo. Map update can download, touchscreen update refuses to.
My VIN is VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] if you can help with licence and firmware.
Thanks a bunch, in advance.
NikolajPedersen Licence File
PSA NAC RCC Updates
NikolajPedersen
Re: PSA NAC RCC Updates
- x 6948
You probably have nor created the licence folder on the USB and extracted the licence file download into this folder.
If you don't, it will not authorise the update.
This is what the USB drive should look like:
NikolajPedersen
You're quite right... I did not. I extracted the .tar so I had an SWL folder and an updateinfo.xml on the USB, and then I just dragged the licence file in next to those.GiveMeABreak wrote: 06 Feb 2024, 10:26 You probably have nor created the licence folder on the USB and extracted the licence file download into this folder.
I'll make the folder and try again. Thanks ever so much
Edit: That was indeed the problem. Thanks again, car is all updated and ready to go!
- x 6948
No problem
ATOJAR
Humm, yeah so I plugged the USB stick into the car and it popped up on the display that there was no media on the stick but nothing else happened? Any idea what I am doing wrong?
Thanks.
Thanks.
- x 6948
Yes, this is because you have copied the files across incorrectly.
For your system you should have the following on the route of the USB and nothing else.
Copy the downloaded licence file into the 'licence' folder (that I told you to create, spelled exactly as shown in the image).
Make sure you do not let your zip utilty create the full pathname of the firmware on the USB or the update will fail.
- x 6948
For your RCC system it may be different, you should have the following on your USB. For RCC systems, it creates a different folder instead of the SWL:ATOJAR wrote: 06 Feb 2024, 16:20 Humm, yeah so I plugged the USB stick into the car and it popped up on the display that there was no media on the stick but nothing else happened? Any idea what I am doing wrong?
Thanks.
Also when you insert the USB, it starts looking for media like MP3 files (which the system can play from USB), just cancel this and it should pick up the update file.
Make sure you have only the file structure as shown on the route of your USB.
ParaBox
@GiveMeABreakParaBox wrote: 31 Jan 2024, 21:23 Hi i would need the firmware and license to update to v 6_0422_23.3137.1
VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
The app doesnt send any download links in the email, but warns update is available.
Thank you
Could you please help me out too?
rab497
I have the same issue on my Dispatch.
Can I get a link?
Can I get a link?
- x 6948
VIN please.
- x 6948
RCC Firmware 6_0422_23.3I37.1
rab497 Licence file
Make sure you format a blank USB as FAT32 and create a folder called licence, where you should then copy the licence fie into.
You should end up with the following files and folders in the route of your USB only:
rab497 Licence file
ATOJAR
Ahh this may be why, I did rename the rcc_update folder to SWL, I will try renaming back to rcc_update and see if that helps.GiveMeABreak wrote: 06 Feb 2024, 17:01For your RCC system it may be different, you should have the following on your USB. For RCC systems, it creates a different folder instead of the SWL:ATOJAR wrote: 06 Feb 2024, 16:20 Humm, yeah so I plugged the USB stick into the car and it popped up on the display that there was no media on the stick but nothing else happened? Any idea what I am doing wrong?
Thanks.
Thanks.
Pablo1568
I Extracted the "PSA_ovip-int-firmware-version_44-07-05-22_NAC-r0_NAC_EUR_WAVE4.tar" directly to My USB stick, and I did create the Folder "licence" , so I had a SWL, Update info and licence on the USB stick. Bought another 32gb usb stick, so Ill try again.GiveMeABreak wrote: 06 Feb 2024, 16:55Yes, this is because you have copied the files across incorrectly.
Pablo1568
What is the file name in the licence folder ? I have: licenses_001315031675246547_20240206210411
rab497
Re: Citroen update?
Amazing. Thanks for the speedy responseGiveMeABreak wrote: 06 Feb 2024, 18:22 RCC Firmware 6_0422_23.3I37.1
rab497 Licence file
