hello all,
could anyone provide a part number that i require (maybe admin) so i could order a new part.
im repairing a c3 picasso 2011.
whilst trying to fill the fuel additive pouch ive snapped a pushfit connector that fits to the additive pump,
its the actual pushfit union thats snapped...it has a small blue pipe that fits to a spigot on the union...its really thin ...its the spigot on that connector thats snapped...
i believe the other end of the thin blue pipe fits to the fuel tank
its hard to explain to citroen parts dept....if i had the part number it would help enormously.
thanks
part number
- x 6950
Re: part number
Hi Moomoo, will be pleased to assist, but your Forum donation has lapsed now, as they only last for up to 2 calendar years.
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
- x 1061
Re: part number
Probably best to also post a pic of the bit you are looking for too.
moomoo
- x 9
Re: part number
Hi Wheeler
I dont have the part only the pushfit fitting thats snapped
...the rest is still fitted to the car but i was laid on the floor and i was freezing my gonads off so decided to leave it for now...I was hoping to get the part number then order up the piece and fit it later in more clement conditions.
moomoo
- x 9
Re: part number
All sorted Marc.....thanksGiveMeABreak wrote: 15 Jan 2024, 18:48 Hi Moomoo, will be pleased to assist, but your Forum donation has lapsed now, as they only last for up to 2 calendar years.
to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum.To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
- x 1504
Re: part number
Thanks for donation, if you post up the VIN, then we can look out the parts diagram to identify the parts.
- x 6950
Re: part number
The bit you want may be on the particle filter harness, but we'll be able to provide you with a diagram once we have your VIN.
moomoo
- x 9
Re: part number
Hello again,
The VIN is.....VF7**************[VIN obfuscated, can be read by forum staff]
It'll be a pipe with (im assuming) a pushfit connector on each end.
Thanks and hopes this helps.
moo
moo
- x 1504
Re: part number
There's a mistake in the VIN, it's F7S (sierra) not F75 (five) - anyway, that's by the by!
Here's the tank detail.
I think it's part 20, Additive supply pipe - item 30 is listed as a harness, so is probably the wiring to the additive pump.
Listed at £66.67 however, and it may well be a drop the tank job to change it....
