Citroen Xsara Picasso 1.6 Hdi 90 Oil Pressure Switch Location
chrisfox15
Unread post by chrisfox15 »
I am looking for some help in locating the oil pressure switch on my Citroen Xsara Picasso 1.6 Hdi 90. I have looked everywhere and cant see to spot it, I was expecting it to be around the oil filter house / Oil Pump but nothing
I will be looking to replace the oil pressure switch and also test the engine has oil pressure
any info or photos would be great
x 6955
Re: Citroen Xsara Picasso 1.6 Hdi 90 Oil Pressure Switch Location
Here you go - it is number 16 on the diagram:
Click diagram to zoom
chrisfox15
Thanks il have a look for it in the morning. is it easy enough to see? can you advise what its closest to? spent so might time with a touch trying to track it down
Cheers
chrisfox15
Found it, Perfect Thanks
x 6955
Sorry - only just seen your previous but one post - but glad you have located it now.
Mikerice
Unread post by Mikerice »
Hi could anyone tell me where the oil pressure switch is on a citroen picasso xsara please would begrateful for a photo
x 6955
It's as above in the diagram - item 16.
Follow the engine oil dip stick guide tube to the bottom. It's immediately behind and just above where the guide tube ends.
Huskyxantia
x 888
Unread post by Huskyxantia »
If wanting to...
Fit an oil pressure gauge to my as below......
2.0hdi 03 picasso
CAN I ?
HOW DO I ?
:-D
Huskyxantia
x 888
chrisfox15 wrote: 17 Feb 2018, 11:23 Found it, Perfect Thanks
So how did you get yours out , looks very much a DPF removal just to do a simple job. No one tells you till you LOOK yourself.
:-D
