I am looking for some help in locating the oil pressure switch on my Citroen Xsara Picasso 1.6 Hdi 90. I have looked everywhere and cant see to spot it, I was expecting it to be around the oil filter house / Oil Pump but nothing
I will be looking to replace the oil pressure switch and also test the engine has oil pressure
any info or photos would be great
Citroen Xsara Picasso 1.6 Hdi 90 Oil Pressure Switch Location
chrisfox15
- x 6956
Re: Citroen Xsara Picasso 1.6 Hdi 90 Oil Pressure Switch Location
Here you go - it is number 16 on the diagram:
Click diagram to zoom
chrisfox15
Thanks il have a look for it in the morning. is it easy enough to see? can you advise what its closest to? spent so might time with a touch trying to track it down
Cheers
Cheers
chrisfox15
Found it, Perfect Thanks
- x 6956
Sorry - only just seen your previous but one post - but glad you have located it now.
Mikerice
Hi could anyone tell me where the oil pressure switch is on a citroen picasso xsara please would begrateful for a photo
- x 6956
It's as above in the diagram - item 16.
Follow the engine oil dip stick guide tube to the bottom. It's immediately behind and just above where the guide tube ends.
Huskyxantia
- x 901
If wanting to...
Fit an oil pressure gauge to my as below......
2.0hdi 03 picasso
CAN I ?
HOW DO I ?
2.0hdi 03 picasso
CAN I ?
HOW DO I ?
Husky.
Huskyxantia
- x 901
So how did you get yours out , looks very much a DPF removal just to do a simple job. No one tells you till you LOOK yourself.
Husky.
