- x 2356
Forgot to attach the pictures!
- x 8415
The tip must have been very concerned at your absence Matt! Did they send a member of staff round to check you were OK...
Good work on the car... I now know what a FRIP joint is
All best with the MoT
- x 2356
Cheers Jim, I've got both the HDi Coupe and the C5 in for test one after the other, so every chance of being carless by the end of the day!
Some good pictures of the new FRIP here:
viewtopic.php?p=755466#p755466
It's a strange thing, don't really understand why it's not just a second ball joints below as well as above. My theory is that they most die off due to water ingress (hence the grease nipple idea) wondering if could add one the the existing bearing in the current part dismantled state to be honest.
- x 8415
They look a bit like a bird's foot Matt!
Grease nipple is a good idea. It's something that was once recommended to do after having a 205/306 et al rear beam overhauled so you could get a decent amount of grease in there...
- x 2356
Plan to add grease nipple to the existing FRIP aborted...
Clearly not as healthy as I first assumed!
- x 8415
Looks like a case of athlete's foot there Matt...MattBLancs wrote: 04 Dec 2023, 13:42 Plan to add grease nipple to the existing FRIP aborted...
- x 2356
Much swearing occured but the inner race is off.
New bearing stuffed with grease. Will tap it on with nipple removed (route for excess grease to escape and sod's law I'd smack it accidentally)
- x 2356
Anyone know which way up the metal ring goes?
Seems to sit against bearing more keenly the opposite way to how it sits best against the hub!? Not particularly enamoured with it's fit on either and it's very generous centre hole let's it sit miles off concentric.
Eenie meeny miny mo coming up shortly!
- x 2356
- x 2356
Brainwave! Is one of those rings, already in place!
- x 8415
Looks like it!
- x 1996
It is....
I added some wax underseal (Bilt&Hamber) to the top of the ring to prevent water collecting/corrosion in the "tray"......and would have done the nipple insert if I had kept the car.
- x 2356
Took some shifting, well mangled by the time it came loose, but old ring removed.
Some grease above the new ring as well as below (just liberally everywhere
Surprisingly robust tapping with the hammer to bring the new FRIP into place.
Swapped to a straight grease nipple, couldn't get the 90° version to engage with the threads again (access limited)
- x 2356
And did remember this heat shield bolt, though only after putting the wheel back on again!
- x 2356
