Xantia doseur valve
x 1071
Re: Xantia doseur valve
Unread post by Rp0thejester »
Looks okay to me :rofl2: for my eyes only, apparently it's been viewed 3 times :rofl2:
x 8391
Sorry to hear about the ribs Skull, having compound broken seven all in one go several years ago I feel your pain :evil:
Here's hoping you soon heal [-o<
RichardW wrote: 11 Oct 2023, 17:12 I recall Jim saying that the carpet can soak up an amazing amount of LHM, but it turns the underneath to mush.
Gosh yes, it can melt all the sound-deadening panel stuck to the footwell under the carpet backing foam. The carpet and foam itself survives well and can be washed out with good, strong detergent and dried but you'll find the carpet will retain a fetching green tinge for the rest of time! As your car is green anyway, that will not be a problem!
The sound deadening mush will need to be scraped away, cleaned up with solvent and a new bit glued in... It's a horrid, dirty job...
Skull
(Donor 2026)
x 380
Unread post by Skull »
CitroJim wrote: 12 Oct 2023, 05:43 Sorry to hear about the ribs Skull, having compound broken seven all in one go several years ago I feel your pain :evil:
Cheers Jim No No I feel your pain today :bigcry: this has taken most of the day ....
Skull's
Skull's
Skull's
Skull's
Can you remember if this foam/rubber mat under the pedals is bonded in at the top :?: Feeling weak ....
Skull's
Skull's
Gary
x 8391
Excellent work Skull :)
Skull wrote: 12 Oct 2023, 17:18
That one is almost impossible to remove, that (and the heater matrix) were the first bits of the car to be assembled and the rest was built around it...
Just clean it up as best you can with lots of absorbent paper and some solvent you know won't attack it...
Skull
(Donor 2026)
x 380
Cheers Jim I thought it had a good grip on the car :oops:
Gary
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
CitroJim wrote: 12 Oct 2023, 17:32 Excellent work Skull :)
I thought Xantias were built around their radiator fans - seems like it when you need to replace them!
x 8391
Armidillo wrote: 12 Oct 2023, 22:28
I guess you've not yet done a heater matrix Alec ;) Radiator fans seem easy in comparison :twisted:
Skull
(Donor 2026)
x 380
All sorted @ 161,060 miles she's back on the road after a short rest :roll:
Not the easiest job to do, I'm going to do a full thread on the job for reference ......
Skull's
Skull's
Gary
Skull
(Donor 2026)
x 380
Full thread is here: DOSEUR VALVE
ADMINS Feel free to move the new thread ^ above ^ to another location if required :wink:
Gary
x 8391
Excellent :D
x 2005
Unread post by Stickyfinger »
Good job.
As for absorbing LHM and other Fluids......cannot get cheaper than these....and they WORK !
On-line or at places like B&M
