Xantia doseur valve
OnlineRp0thejester
- x 1070
Re: Xantia doseur valve
Looks okay to me
for my eyes only, apparently it's been viewed 3 times
Champion of Where's CitroJim
- x 8391
Sorry to hear about the ribs Skull, having compound broken seven all in one go several years ago I feel your pain
Here's hoping you soon heal
The sound deadening mush will need to be scraped away, cleaned up with solvent and a new bit glued in... It's a horrid, dirty job...
Gosh yes, it can melt all the sound-deadening panel stuck to the footwell under the carpet backing foam. The carpet and foam itself survives well and can be washed out with good, strong detergent and dried but you'll find the carpet will retain a fetching green tinge for the rest of time! As your car is green anyway, that will not be a problem!RichardW wrote: 11 Oct 2023, 17:12 I recall Jim saying that the carpet can soak up an amazing amount of LHM, but it turns the underneath to mush.
Skull
- (Donor 2026)
- x 380
Cheers Jim No No I feel your pain todayCitroJim wrote: 12 Oct 2023, 05:43 Sorry to hear about the ribs Skull, having compound broken seven all in one go several years ago I feel your pain
Here's hoping you soon heal![]()
Can you remember if this foam/rubber mat under the pedals is bonded in at the top
Gary
Gary
- x 8391
Excellent work Skull
Just clean it up as best you can with lots of absorbent paper and some solvent you know won't attack it...
That one is almost impossible to remove, that (and the heater matrix) were the first bits of the car to be assembled and the rest was built around it...Skull wrote: 12 Oct 2023, 17:18
Can you remember if this foam/rubber mat under the pedals is bonded in at the topFeeling weak ....
Skull
- (Donor 2026)
- x 380
Cheers Jim I thought it had a good grip on the car
Gary
Gary
Armidillo
- x 274
I thought Xantias were built around their radiator fans - seems like it when you need to replace them!CitroJim wrote: 12 Oct 2023, 17:32 Excellent work Skull
- x 8391
Armidillo wrote: 12 Oct 2023, 22:28I thought Xantias were built around their radiator fans - seems like it when you need to replace them!CitroJim wrote: 12 Oct 2023, 17:32 Excellent work Skull
I guess you've not yet done a heater matrix Alec
Skull
- (Donor 2026)
- x 380
All sorted @ 161,060 miles she's back on the road after a short rest
Not the easiest job to do, I'm going to do a full thread on the job for reference ......
Gary
Gary
Skull
- (Donor 2026)
- x 380
Full thread is here: DOSEUR VALVE
ADMINS Feel free to move the new thread ^ above ^ to another location if required
Gary
Gary
- x 8391
- x 2004
Good job.
As for absorbing LHM and other Fluids......cannot get cheaper than these....and they WORK !
On-line or at places like B&M
