Hi All.
I have a 2016 Citroen C4 1.6 HDIBlue, and the front left indicator has stopped working. Citroen are quoting over £600 for a new assembly. To essentially change a bulb! Please Can anyone help?.
Citroen C4 indicator/headlight cluster issue?!
- x 1488
Re: Citroen C4 indicator/headlight cluster issue?!
I imagine it's an LED unit and there are 'no user serviceable parts inside'!! Getting one from a breaker seems like the best plan.
Chrisr77
I had a bad feeling this would be the case, thank you.
- x 6957
There are 3 possibilities of headlamp fitted: Discharge Bulb Type, Halogen Bulb Type or LED + Halogen Type.
- x 1943
Are any of those linked with a specific type of indicator bulb?
- x 6957
Yes, from what I can see...
Discharge Bulb Headlamp Type has a PY21W Orange Indicator Bulb
Halogen Bulb Headlamp Type has a H21W Bulb for indicator function
LED + Halogen Headlamp Type has neither - so assume this is the type the OP has, but VIN would confirm. This being the case, the complete Headlamp is showing a tad under £800 at today's prices.
Chrisr77
Yeah it’s a LED + Halogen Headlamp
. It’s a bit of a nightmare having to pay that much for a replacement indicator!
Reason: Image fixed
Reason: Image fixed
- x 6957
Indeed - it's the way of things - new tech at rip off prices things that are generally cheaper to make than standard lamps! It's all modular these days - plug in and replace the same way, and charge 4 times as much.
Chrisr77
I wonder if I can replace the LED + Halogen Headlamp with a Halogen Bulb Headlamp Type…
- x 1488
It was put together, so it may be possible to dismantle it, and replace the LED. There's a recent thread on here where XantiaV6 replaced the LEDs on a 308 CC rear cluster.
- x 6957
I doubt that will work at all, as these units are operated and controlled differently with different power requirements and software than the other types. You would be better initially looking for a second hand one from a breakers or on ebay.Chrisr77 wrote: 11 Oct 2023, 21:08 I wonder if I can replace the LED + Halogen Headlamp with a Halogen Bulb Headlamp Type…
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, but we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
Galactica
- New User
Hello,
We are able to repair the problem. The headlight needs to be dissasembled in order to be repaired. Problem is that we are situated in Bulgaria, and UK is outside EU, which will affect the repair cost drastically.
LED headlight repairs - https://galacticautoled.com/
