- x 6955
No, your caliper isn't electrically operated, but it is controlled by cables via the electronic handbrake, but there are no electronics on the caliper itself.
(4) Rear Brake Caliper (Left), part: 1610900880, £396.74
(5) Brake Caliper Yoke, part: 4404G2, £232.30
- x 3302
As parts 8 and 21 still available? If so, how much is 21? What is the part number for 8? Thanks.
OnlineHuskyxantia
- x 893
Is there part numbers for the road wheel bolts ? For 308cc vin
Husky.
Dunkah
- x 11
Hi Marc, the battery clip on my battery tray is a little broken, can you sort an exploded diagram
Many thanks
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
- x 6955
I would tell you if parts were NOT available James.Hell Razor5543 wrote: 27 Sep 2023, 12:51As parts 8 and 21 still available? If so, how much is 21? What is the part number for 8? Thanks.
(21) Fuel Return Pipe, part: 15731E, £30.44
I've already provided the part number for (8) in the original reply.
- x 6955
For alloy wheels, the bolt (12X125) is part: 9817024580, £6.24 eachHuskyxantia wrote: 27 Sep 2023, 16:02 Is there part numbers for the road wheel bolts ? For 308cc vin
OnlineHuskyxantia
- x 893
Thank you marc.
Husky.
- x 6955
You won't have all the parts shown on this diagram, so let me know any item numbers for which you require a part number for.Dunkah wrote: 27 Sep 2023, 21:14 Hi Marc, the battery clip on my battery tray is a little broken, can you sort an exploded diagram
Many thanks
Dunkah
- x 11
Don’t think it appears on that diagram as a numbered part. It’s the twist lock part of the clip, pics attached
Possibly part 17?
Or part no 20 to include the whole tray?
Possibly part 17?
- x 3302
Sorry, my mistake. I meant 21! Thanks for your help, Marc.GiveMeABreak wrote: 27 Sep 2023, 21:57I would tell you if parts were NOT available James.Hell Razor5543 wrote: 27 Sep 2023, 12:51As parts 8 and 21 still available? If so, how much is 21? What is the part number for 8? Thanks.
tearing hair out
- x 19
Hi Marc,
Could I trouble you for a part number for a mass airflow sensor for my C8 please? I haven't got the VIN to hand, but I think you should still be able to see it here: viewtopic.php?p=759416#p759416
(Interestingly, you've previously told me the parts catalog doesn't show a fuel cap presence sensor on mine, but I've definitely got one - I've tried unplugging it and the computer instantly decides the fuel cap is in place, but the sensor is permanently closed-circuit ("cap missing").)
Kind regards,
Paul
Kind regards,
Paul
Paul
I would have more Citroens if I had the space...
- x 6955
Yes part (20) contains the locking mechanism and is not available separately.Dunkah wrote: 27 Sep 2023, 22:49 Don’t think it appears on that diagram as a numbered part. It’s the twist lock part of the clip, pics attached
Possibly part 17?
(20) Battery Tray, part: 6545SJ, £70.15
jordyh
- x 4
Hi,
Could you please let me know if there is a specific part for the wiring harness from the drivers rear parking brake to (from reading other posts) a connector under the rear seats? Been repaired once so want to replace the entire thing if I can.
Mk2 Picasso VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks,
Jordan.
Many thanks,
Jordan.
- x 6955
Ok, so as for the fuel cap sensor, there are 2 variants of the system fitted to the C8 and I previously must have looked at the other alternative. So in your case it will be this diagram which shows it at (31):tearing hair out wrote: 28 Sep 2023, 09:33 Hi Marc,
Kind regards,
Paul
MAF
(21) Flowmeter (Diam 80), part: 1920AG (NFP: No longer available from Citroen)
You should still be able to get one on the aftermarket using this part number.
tearing hair out
- x 19
Thanks Marc - yes they seem to be available for about £40. Just wanted to be sure I was getting the right one.
(Oh and how much I used to dread "NFP" while I was running a CX...)
Paul
