x 6955
No, your caliper isn't electrically operated, but it is controlled by cables via the electronic handbrake, but there are no electronics on the caliper itself.
(4) Rear Brake Caliper (Left), part: 1610900880, £396.74
(5) Brake Caliper Yoke, part: 4404G2, £232.30
x 3302
GiveMeABreak wrote: 18 Sep 2023, 19:45 Image
If it's (8), then part: 1579PJ, £129.94
As parts 8 and 21 still available? If so, how much is 21? What is the part number for 8? Thanks.
Huskyxantia
x 896
Unread post by Huskyxantia »
Is there part numbers for the road wheel bolts ? For 308cc vin
:-D
Dunkah
x 11
Unread post by Dunkah »
Hi Marc, the battery clip on my battery tray is a little broken, can you sort an exploded diagram
Many thanks
Vin VF7**************[VIN obfuscated, can be read by forum staff]
x 6955
Hell Razor5543 wrote: 27 Sep 2023, 12:51
I would tell you if parts were NOT available James.
(21) Fuel Return Pipe, part: 15731E, £30.44
I've already provided the part number for (8) in the original reply.
x 6955
Huskyxantia wrote: 27 Sep 2023, 16:02 Is there part numbers for the road wheel bolts ? For 308cc vin
For alloy wheels, the bolt (12X125) is part: 9817024580, £6.24 each
Huskyxantia
x 896
Thank you marc.
:-D
x 6955
Dunkah wrote: 27 Sep 2023, 21:14 Hi Marc, the battery clip on my battery tray is a little broken, can you sort an exploded diagram
Many thanks
You won't have all the parts shown on this diagram, so let me know any item numbers for which you require a part number for.
Dunkah
x 11
Don’t think it appears on that diagram as a numbered part. It’s the twist lock part of the clip, pics attached
Possibly part 17?
Or part no 20 to include the whole tray?
x 3302
GiveMeABreak wrote: 27 Sep 2023, 21:57
Sorry, my mistake. I meant 21! Thanks for your help, Marc.
tearing hair out
x 19
Unread post by tearing hair out »
Hi Marc,
Could I trouble you for a part number for a mass airflow sensor for my C8 please? I haven't got the VIN to hand, but I think you should still be able to see it here: viewtopic.php?p=759416#p759416
(Interestingly, you've previously told me the parts catalog doesn't show a fuel cap presence sensor on mine, but I've definitely got one - I've tried unplugging it and the computer instantly decides the fuel cap is in place, but the sensor is permanently closed-circuit ("cap missing").)
Kind regards,
Paul
Paul
I would have more Citroens if I had the space...
x 6955
Dunkah wrote: 27 Sep 2023, 22:49 Don’t think it appears on that diagram as a numbered part. It’s the twist lock part of the clip, pics attached
Possibly part 17?
Yes part (20) contains the locking mechanism and is not available separately.
(20) Battery Tray, part: 6545SJ, £70.15
jordyh
x 4
Unread post by jordyh »
Hi,
Could you please let me know if there is a specific part for the wiring harness from the drivers rear parking brake to (from reading other posts) a connector under the rear seats? Been repaired once so want to replace the entire thing if I can.
Mk2 Picasso VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks,
Jordan.
x 6955
tearing hair out wrote: 28 Sep 2023, 09:33 Hi Marc,
Kind regards,
Paul
Ok, so as for the fuel cap sensor, there are 2 variants of the system fitted to the C8 and I previously must have looked at the other alternative. So in your case it will be this diagram which shows it at (31):
MAF
(21) Flowmeter (Diam 80), part: 1920AG (NFP: No longer available from Citroen)
You should still be able to get one on the aftermarket using this part number.
tearing hair out
x 19
Thanks Marc - yes they seem to be available for about £40. Just wanted to be sure I was getting the right one. :-)
(Oh and how much I used to dread "NFP" while I was running a CX...)
Paul
