c.morewood
- x 55
Thanks for the above Marc. Sorry been away for a few days. I found a replacement in Hungary by googling the part number.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Huskyxantia
- x 928
Needing Caliper part numbers for 308cc vin is VF3**************[VIN obfuscated, can be read by forum staff] cheers marc, the driver side rear please, piston won't retract ive tried eveything time for a new caliper i think. Thanks.
Same car part numbers for the rear off side brake pipe caliper to axle i think its called that. Cheers.
Husky.
- x 6950
Rear Caliper
(5) Rear Caliper (Right) part: 4401N7, £256.98
Rear Pipes
Not sure which one you need, so here are the possibilities:
(2) Brake Hose Rear
OEM Original, part: 4806A1, £13.25
Cheaper: 1623257180, £14.65 (Yes OEM part is actually cheaper than the cheaper part!)
(15) Brake Hose
Part: 4888K9, £164.80
(17) Brake Hose
OEM, part: 4886Z7, £26.66
Cheaper, part: 1680022480, £30.58
Rear Pipes
(2) Brake Hose Rear
(15) Brake Hose
(17) Brake Hose
Huskyxantia
- x 928
Cheers marc, think id better have the rear left caliper part number too, might be best to do both sides i guess, same car.
Husky.
- x 6950
(5) Rear Caliper (Left), part: 4401N6.
Michel
Please could you tell me what size front discs were originally fitted to my Picasso?
Thanks!
Thanks!
- x 6950
DIAM 266 EP 22
Michel
Brilliant, thanks Marc
OnlineHell Razor5543
- x 3298
Please can I have the part code (or codes) for the pipes that connect between the fuel tank and the fuel filter? I do not know if they are a combined part or separate pipes.
- x 6950
If it's (8), then part: 1579PJ, £129.94
- x 3298
Thank you, Marc.
- x 3298
What is item 23?
- x 6950
That is the fuel cooler
Dunkah
- x 11
Parts diagram request
Hi, could I please get an exploded diagram and associated parts list. Thanks
Parts in question are front suspension, not hydraulic but struts/wishbone areas
2008 c5 x7 tourer, 2ltr hdi
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Reason: Moved to Parts thread
- x 6950
Please advise of actual item numbers for which you require a part number:
Strut Hub, Pivots, Bearing
