c.morewood
x 55
Unread post by c.morewood »
Thanks for the above Marc. Sorry been away for a few days. I found a replacement in Hungary by googling the part number.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
Huskyxantia
x 926
Unread post by Huskyxantia »
Needing Caliper part numbers for 308cc vin is VF3**************[VIN obfuscated, can be read by forum staff] cheers marc, the driver side rear please, piston won't retract ive tried eveything time for a new caliper i think. Thanks.
Same car part numbers for the rear off side brake pipe caliper to axle i think its called that. Cheers.
:-D
x 6947
Rear Caliper
(5) Rear Caliper (Right) part: 4401N7, £256.98
Rear Pipes
Not sure which one you need, so here are the possibilities:
(2) Brake Hose Rear
OEM Original, part: 4806A1, £13.25
Cheaper: 1623257180, £14.65 (Yes OEM part is actually cheaper than the cheaper part!)
(15) Brake Hose
Part: 4888K9, £164.80
(17) Brake Hose
OEM, part: 4886Z7, £26.66
Cheaper, part: 1680022480, £30.58
Huskyxantia
x 926
Cheers marc, think id better have the rear left caliper part number too, might be best to do both sides i guess, same car.
:-D
x 6947
(5) Rear Caliper (Left), part: 4401N6.
Michel
Unread post by Michel »
Please could you tell me what size front discs were originally fitted to my Picasso?
Thanks!
x 6947
DIAM 266 EP 22
Michel
GiveMeABreak wrote: 17 Sep 2023, 14:19
DIAM 266 EP 22
Brilliant, thanks Marc
x 3298
Please can I have the part code (or codes) for the pipes that connect between the fuel tank and the fuel filter? I do not know if they are a combined part or separate pipes.
x 6947
If it's (8), then part: 1579PJ, £129.94
x 3298
Thank you, Marc.
x 3298
GiveMeABreak wrote: 18 Sep 2023, 19:45 Image
What is item 23?
x 6947
That is the fuel cooler
Dunkah
x 11
Parts diagram request
Unread post by Dunkah »
Hi, could I please get an exploded diagram and associated parts list. Thanks
Parts in question are front suspension, not hydraulic but struts/wishbone areas
2008 c5 x7 tourer, 2ltr hdi
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Reason: Moved to Parts thread
x 6947
Please advise of actual item numbers for which you require a part number:
Strut
Hub, Pivots, Bearing
