Steering rack PTFE seals help needed
darbuck
x 291
Unread post by darbuck »
Hi all I need a hand sourcing seals. Does anyone know where I would get PTFE square profile rings.
Darren
Sloppysod
x 391
Re: Steering rack PTFE seals help needed
Unread post by Sloppysod »
darbuck wrote: 07 Sep 2023, 16:04 Hi all I need a hand sourcing seals. Does anyone know where I would get PTFE square profile rings.
you don't mentiin what vehicle and where do the seal fit.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
KennyW
x 164
Unread post by KennyW »
Stu,
It's the C5
C3 1.4 petrol (SWMBO)
Sloppysod
x 391
cheers kenny, its just the square profile that confused me. 👍
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
darbuck
x 291
It's for the rack Kenny piston seal and rack bar bushes
Darren
darbuck
x 291
Sloppysod wrote: 09 Sep 2023, 15:59
Its for the rack Stu, piston seal and rack bar bushes. The only thing I can find is a chap that will make them out of acetal which is a very similar coefficient of friction,Young's modulus, chemical and pressure resistance all very similar. Temperature resistance is lower but if it reaches critical temperature the hoses will probably fail first anyway. The large ring is the piston ring PTFE section.
Darren
KennyW
x 164
Darren,
Have you found your seals ? the reason I'm asking PTFE and teflon are the same ploy tetra fluro ethylene. There are companies out there but may need specialised cutting.
Kenny
darbuck
x 291
I know they are I just use them interchangeably. I might have a manufacturer in the UK a bit steep at £100 but he is making them to order . But he is using acetal
Darren
x 1066
Unread post by Rp0thejester »
Looks like we might have a contender for worst C5, hoping they read this thread. And your fuel regulater fault.
darbuck
x 291
It's an absolute lemon but I nearly have it sorted.dont forget two sets of wiper motors in 9 months.
Darren
x 1066
Anything can be rescued with enough love, care, blood, sweat, blood, swear words, blood and more blood.
darbuck
x 291
Totally agree and all of the above are in this car
Darren
Jay-Bruce
x 280
Unread post by Jay-Bruce »
Swan Seals in Aberdeen have dug me out of a hole a few times machining up otherwise unobtainable seals, however, as they are an Aberdeen company, their pricing model is "geared towards Oil & Gas".
darbuck
x 291
Do you know if they do PTFE
Darren
Jay-Bruce
x 280
Yes, they do :-)
https://www.swanseals.co.uk/seal-materials
To be honest with you, PTFE is actually a sweetheart of a material to machine, so virtually any machine shop should be able to turn these down. Even I've turned down PTFE Rollers for the guides on small winches offshore.
