Xantia Wing replaced Before and After (During available)
Skull
(Donor 2026)
x 382
Unread post by Skull »
Skull's rusty wing (26 years)
Skull's DIY Rattle Can
Thanks to Stickyfingers for saving them :wink:
Thanks to Mickthemaverick / CitroJim for transporting/storage =D>
Gary
x 8172
Re: Xantia Wing replaced Before and After (During available) )
Excellent job, that looks a better match than the original!! :-D
x 2008
Unread post by Stickyfinger »
Ohhh.....they look good. I just knew they would come in handy one day......that was about 7 years they hung in the garage roof !
x 8457
Superb :D Delighted it's all come good! It's certainly looking good :)
Skull
(Donor 2026)
x 382
During …..
Skull’s - Bottom of wing disappeared
Skull’s - Bumper removed to reveal rust patches
Skull’s - Bumper seemed to allow capillary action to wing
Skull’s - rust from wing
Skull’s - Bumper and Wing removed
Skull’s - Rusty bracket
Skull’s - Rusty Wheel Arch Liner Bracket
Skull’s - Sill with captive nut
Skull’s - Sill after cleaning- nut disappeared inside
Skull’s - decided to touch up sill - Jenolite Jelly
Skull’s - Sill primed
Skull’s - Sill painted
Gary
x 8457
Excellent! That'll be good for another 20 years :D
civvie
x 20
Unread post by civvie »
That wing looks great, have always been scared to touch up panels with a can, never think I can get it to look good again.
Steve
C5 2.2hdi auto until I sell it (sold it) now have Peugeot 3008 1.6HDI (Now sold)
Had the jab a couple of days ago. Feb 21
x 8172
It used to be near impossible to get a good match with rattle cans but nowadays the technology for producing the right colour has moved on to the point that all you have to worry about is getting an even run free finish. It is helped by modern paints holding their true colour much better so if working on a late 20th or 21st century car it really is quite easy to get a good finish.
However I still believe it is better to have the paint mixed for you and not buy a 'ready made' variety from accessory shops. There are a number of companies who will do it and send it to you.
I'll edit in the one I use here when on my laptop :-D
x 3298
Some people have brilliant colour perception, and can work out the correct colour makeup just by looking at a sample.
civvie
x 20
Mick. Understand what you are saying, I got one of those cans that is supposed to match the colour code for the car, its still sitting here unused. My problem is how to actually do it. If I mask the area to be touched up I am scared of leaving a line where the masking was, if I don't mask well it can go everywhere. I have a small area nearside wing down low near the front that has a small scrape mark, the sort of mark when you try and get out of a tight spot, and miss judge distances when turning. I also got one of those touch up brushes in the end used one of those, it covers to help prevent rust but is not perfect.
Steve
x 8172
This is an example from my supplier:
https://www.ebay.co.uk/itm/392371953474 ... 1369645853
I have bought a number from them and never had a bad match. As for the hard masking line, one technique that works quite well is to loosely fold the masking tape back on itself so that the edge is a 'curl' in the tape. When you paint some will go under the curl and some will not giving you a soft join which once set after 48 hours at least you can cut back and produce a flowing blend. Give it a go, one good thing is that any paint job can always be redone if it goes wrong!! :-D
Skull
(Donor 2026)
x 382
Mickthemaverick I've used the same supplier prior to this attempt, I did have one touch-up pot from there that was very opaque, I got this job from my local auto shop, 'custom mix' - not the cheapest but the colour is good and the metallic content seems ok, there is some paint spots caused (I believe) by pigments not mixing fully.
I also need to clean up the lower edge of the ns front door which has started to get scabby ....
civvie wrote: 31 Aug 2023, 08:46 That wing looks great, have always been scared to touch up panels with a can, never think I can get it to look good again.
civvie I didn't really have a choice here as the wing had started to disappear :roll: The replacement wing was also off the car whilst I sprayed it :wink: I would have liked a better shine and I'm hoping a mild cutting paste will help in a couple of weeks ....
Gary
civvie
x 20
Thanks lads for the update, May give it a go when pluck up courage. After a bottle of wine !!
Steve
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
LOOKS FAB!
When can you start mine, Civvie? :rofl2:
civvie
x 20
You only want to share the wine...
Steve
