Peugeot 207 1.6hdi Everything about.
Huskyxantia
- x 918
Re: Peugeot 207 1.6hdi Everything about.
Your know when its done as a muscle in the back rips lol
Husky.
Huskyxantia
- x 918
Video library
Rear shock change
Rear shock change
Husky.
Huskyxantia
- x 918
207 1.4hdi Timing belt replacement
Husky.
Huskyxantia
- x 918
1.6hdi timing belt replacement
Husky.
Huskyxantia
- x 918
Web search for torque settings 207 rear hub nut is as confusing as follows.
65,180,300 Nm all specs for rear hub nut tightness wonder why we all get things wrong ?
Husky.
willnz
- x 3
According to Peugeot Servicebox, torque is 30m daN which converts to 300Nm
Huskyxantia
- x 918
Adjusted the rear brake shoes , slackened off the handbrake cable first when i removed the drum what a pleasant surprise both sides revealed ,so the adjusting was done as by the correct way , now i can feel all the brakes doing that nice squeeze they do
Husky.
Huskyxantia
- x 918
As above, everything was lightly grease that had movement springs were lightly coated and them horrid spring clips too
Husky.
Huskyxantia
- x 918
Time to replace the inner tie rods . Can the rubber gaiters be pulled back so i can get the special tool in to undo the rod
Any one done this little job comments hints tips please comment on this post .
Husky.
Huskyxantia
- x 918
Husky.
Huskyxantia
- x 918
Under took the job shown in the above video today , Took 10 mins each side the special tool for undoing the inner rod is a must , its cheap £6 ebay can't do it with out it . The inner tie rods where £25.68 for 2 ebay, brand Fibe bilstein.
Husky.
Huskyxantia
- x 918
Need to check the inner tie rod gators soon to make sure the clips haven't moved , do have new ones if there needed , but after i changed the inner rods i rested the car for a few weeks and used the 308cc now the 308cc needs the calipers doing i can get this done rest the 207 then check the gaiter clips replace if need be.
Husky.
Huskyxantia
- x 918
207 just had 2 new tyres black friday deal 2 for 80 quid all in & on the drive ! Mid range too.
Husky.
