DS5 Headlights
Robk
DS5 Headlights
I recently purchased a 2016 DS5 and unfortunately it has had a bad repair job. I am getting the Directional light error. The headlights have been swapped out with the Pre-facelift versions and I want to know if there is anyway that the BSI can be programmed to accept the old type lights? Part number for the lights that are installed are 9802086780, and I assume that I need to expensive LED lights.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
- x 6948
Re: DS5 Headlights
Onthis vehicle the engine fuse box is configurable, and there are options for lighting that have to be set here, and possibly in the BSI too.
This original headlamp unit was the version with Xenons and LEDs combined, so may have specific software / configuration to operate but I can tell you that you will have the incorrect headlamp auto adjuster unit as these are different parts depending on the pre and post facelifted models amongst other possible differences. So configuration of the headlamp ECU will be impossible if the wrong lighting units are fitted I suspect.
Robk
Re: DS5 Headlights
Thanks for the reply. The DRL LED's and the Xenons work fine. The main beams are a problem as they don't turn on. I assume I would have to run a new wire to them from the engine fuse box. I would need to know what fuse socket to use and if the Main beam selector would send a signal to the new fuse to turn them on.
If I could turn off the auto adjusters on the headlights that would be an easy option as well.
- x 6948
Re: DS5 Headlights
No that won't work. The system is ECU controlled and you can't just go running wires to fuseboxes and ECUs expecting it to work.
You need the correct headlights, ECU, software and programming for this to work.
Robk
Re: DS5 Headlights
OK thanks. I will keep an eye out for a used pair.
NotAnInterestingName
- x 51
Re: DS5 Headlights
Have a look at the label, see if you can see who makes them FOR Citroen/DS.
I've just been buying headlights for the Berlingo, in that case they are made by Valeo, see the bunch of logos on the label...
From a bit of shopping around, I've now ordered one made by Valeo for £130 inc delivery instead of the £369 that Citroen would charge.
This is a 65% saving for a brand new identical original light, not a lookalike or pattern part. The only difference is that it won't have a Peugeot/Citroen logo on the box or label.
You may be able to do a similar process for yours.
There are other cheapo Taiwanese/Chinese/Whatever copy ones for around £100, but it's not worth the risk for the tiny additional saving, they could be LHD or just crap.
I'd avoid used, the Berlingo ones are crazing at 9 years old and will probably become cloudy in another few. I needed to replace one due to accident damage but decided to just replace both while I'm at it, as they're so cheap.
- x 6948
Re: DS5 Headlights
NotAnInterestingName wrote: 02 Aug 2023, 13:56 From a bit of shopping around, I've now ordered one made by Valeo for £130 inc delivery instead of the £369 that Citroen would charge.
I've had a look at the Valeo catalogue and they're not listed at all in there unfortunately.
- x 51
Re: DS5 Headlights
Crikey, I'll try not to crash our DS5 head-on into anything then.
This may be an issue when they inevitably start turning opaque in the future. No signs so far, hopefully they're more UV-resistant than the Berlingo ones, which are developing surface crazing at 8-9 years old. Given the price of the Valeo ones I'm replacing them, but I definitely would look into polishing and/or coatings if I was looking at £3400+.
I suppose they have to justify the price of the car by charging silly money for the unique parts. The DS5 is basically a tarted-up Berlingo/C4/Peugeot 308 estate, so the oily bits are all bog standard cheapo bits but the posh bits certainly make up the difference.
- x 6948
Re: DS5 Headlights
Xenons have always been very expensive, my C5 X7 Xenons are £1351 each new, so add in the LED tech on the combined units into the mix and it soon adds up.
The later LED signature lamps are a bit more reasonable now with the new C5 X (2022) bare headlamp being just under £800, with the ECU another £164, so cheaper as I would expect with the later tech - but still expensive for what they are.
Robk
Re: DS5 Headlights
Marc, could you please let me know the specific part numbers for my vehicle. Having looked at some previous posts, I see you had this part number for a similar car to mine?
Lamp Part number: 1613381080, £1411.76 inc. VAT
Right Lamp Part Number: 1613380980, £1411.76 inc. VAT
Robk
Re: DS5 Headlights
Do you think you can see if you can take a photo of the label on the headlights. Maybe the manufacturer is listed there. There are hardly any photos online of these lights and I cant find one of the label.NotAnInterestingName wrote: 02 Aug 2023, 13:56 Have a look at the label, see if you can see who makes them FOR Citroen/DS.
- x 6948
Re: DS5 Headlights
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.Robk wrote: 04 Aug 2023, 06:54 Marc, could you please let me know the specific part numbers for my vehicle. Having looked at some previous posts, I see you had this part number for a similar car to mine?
If interested, links are below, then pop your VIN up.
Robk
Re: DS5 Headlights
Thanks for letting me know, I have done the donation. This is a great source of info.
My VIN - VF7**************[VIN obfuscated, can be read by forum staff]
- x 6948
Re: DS5 Headlights
Ok, so here you go:
(1) Bare Headlamp (Left) part: 1613381280, £1,731.88
(1) Bare Headlamp (Right) 1613381180, £1.757.90
UK VAT 20% Inclusive, direct from Citroen / DS Autos
- x 51
Re: DS5 Headlights
These are the lights on my 2016 DS-Brand DS5. This is the HID/LED one, the poshest version...
Left: Right: Someone will know who the manufacturer is from that logo (it's not Valeo), might be worth hunting them down and emailing them. You never know, they might be £20 without the Citroen markup!
CCC is China's safety accreditation, just googled it. They sold lots of DS5s in China, so it might be worth checking Chinese websites, e.g. AliExpress. I bought a used door handle on there.
