Key programming
ozvtr
x 257
Re: Key programming
Unread post by ozvtr »
wheeler wrote: 22 Jul 2023, 07:34 First i've heard of that one? what vehicles are you saying this in the case on? On my Old X7 C5 (which is full CAN like the vehicle in question) i had 3 fully functioning remotes, 2 originals & one aftermarket)
Ach! Sorry, stuck in the VAN-BUS past.
x 1955
Re: Key programming
Following the Ebay link, the video in the description is interesting as it shows a key tester which displays both frequency and modulation type. All testers I've found on Ebay don't show whether the signal is ASK or FSK. It doesn't look like a very expensive tester (said he, hopefully) but where to get one from?
x 1061
Re: Key programming
Unread post by wheeler »
ozvtr wrote: 24 Jul 2023, 09:50
Even on VAN/CAN i have never heard that only 2 out of the 5 keys can be remotes. Cant think if i have ever tried it either on the VAN/CAN systems though. Never seen any docs or anything in Lexia menus that i can think.
On a side note I recently programmed a proximity key to a Kia Sportage (around 2019 model) & it turns out these can only have 2 keys programmed into them at the one time in total :shock: this is the lowest amount of key slots i have ever seen on a car. Most vehicle will allow 4-5, some Merc & BMW allow 10.
ozvtr
x 257
Re: Key programming
I have it from a good authority, a guy who cracked the VAN BUS remote transmitter and transponder pairing encoding.
Started a post on Digital KAOS. Builds and sells his own scanner and decoder software. Probably not worth the money this late in the day if you know what I mean.
https://cartools.lv/PDFs/PSA_remote_reader.pdf
The instructions warn that the BSI will not accept more than 2 remotes.
Is he wrong? Well I'm not going to tell him. :-D
If you can scan the output of the remote, the common data stored on the transponder chip can be decoded from the stream. You can then give that stream to some guys on digital KAOS and they will decode the data to write onto the transponder.
I am trying to get a universal receiver and hitag2 writer to work at the moment. I should then be able to get my first used remote to work.
x 1061
Re: Key programming
As i sad i dont recall ever trying to add more that 2 on a VAN/CAN BSI but I don’t recall Lexia ever saying only 2 allowed.
x 1955
Re: Key programming
Anyone have any idea about this?
Paul-R wrote: 24 Jul 2023, 11:34 Following the Ebay link, the video in the description is interesting as it shows a key tester which displays both frequency and modulation type. All testers I've found on Ebay don't show whether the signal is ASK or FSK. It doesn't look like a very expensive tester (said he, hopefully) but where to get one from?
x 1061
Re: Key programming
Just had a look at the video, the tester they are using is the VVDI key tool Max, They are around £350. Its a bit more than a signal checker, Its main use is for generating the universal remotes we have previously spoke about. It also generates & clones transponder chips and can be used for unlocking used remotes to virginise them.
I have the key tool mini which has the same functions but doesent have its own screen like the one in the video, you use an app on your phone to connect to it & display the info
x 1955
Re: Key programming
Thanks Wheeler. Appreciate the information.
