engine FAULT replacement needed on citroen ds4 2012[engine checklight
LOVEMORE
Unread post by LOVEMORE »
when l turn ON ignition this notification pop up [engine fault replacement needed] 3pop up 3 times
and dessappear leaving engine checklight on on dash board ,tried to clear it bt later on it comes back ,wat might bre the problem and how CAN L FIX IT
x 6955
Re: engine FAULT replacement needed on citroen ds4 2012[engine checklight
That can be a generic warning and I think you'll find it says REPAIR needed not 'replacement'.
The only way to get some idea is to have it diagnosed with Diagbox and provide us with the fault codes, along with the vehicle's VIN.
LOVEMORE
Re: engine FAULT repair needed on citroen ds4 2012[engine checklight
It was diagonosed and the inspection results are;
1.signal error transmitted by the engine management ECU over the CAN NETWORK.INCORRECT VALUE RECEIVED
ERROR CODE U1208
x 6955
Ok, so you need to provide the 17 digit VIN for the vehicle usually found in the bottom left corner of the windscreen in a small cut out. It will begin with 'V'. I can then associate the fault code correctly.
LOVEMORE
VIN NUMBER VF7**************[VIN obfuscated, can be read by forum staff]
x 6955
Here you are:
Fault Code: U1208
Description of Fault: No communication with the engine management ECU fault: Value received incorrect. The engine ECU gives invalid data or information that is too short.
Switching on of the warning lamp and/or warning message Warning lamp
- "a" : Not on
- "b" : Not on
- "c" : Not on
Conditions for Fault to clear: -
Downgrade Modes whilst Fault is active: No back-up mode
Symptoms:
  • Illumination of LED/Error message *
  • Electrically-controlled parking brake does not apply correctly
  • Electrically-controlled parking brake releases unexpectedly
  • The hill start assist is not working
Suspect Areas:
  • Engine ECU
* Switching on of the warning lamp and/or warning message
"a": Electric parking brake fault warning lamp
"b": Electric parking brake warning lamp
"c": Service warning lamp
LOVEMORE
Thank you soo much,may you assist with a diagram the exactly positions that need to be checked
Reason: Changed from all Caps
x 6955
This is just to help fault finding. You'll need to check all the connections to the Engine ECU and make sure there is no damaged wiring.
LOVEMORE
Noted with thanks
LOVEMORE
Hello l m stuck with think U1208 fault code may you assist on how to fix this
x 6955
There is no standard 'fix' The code is there to assist with onward troubleshooting. But if you have checked all your electrical connections to the Engine ECU and the indicated warning lamps are NOT on as shown in the fault code analysis above, then you may have an issue with the engine ECU itself.
Basically the Engine ECU is not communicating or is sending incorrect data. This can often happen if the connections to the engine ECU have been removed and nor reconnected properly or there is a damaged wire. Also has the engine ECU been exposed to any water which may have gotten in. I would be checking the connections and the pins to make sure there is no corrosion or damage to the pins.
x 1480
What engine is in it?
x 6955
This is a 1.6 THP 16V 163 (EP6CDT M) Richard.
LOVEMORE
Yes srry for late response
LOVEMORE
UPSTREAM OXYGEN SENSOR MIXTURE TOO LEAN fault code P2195
Hello may you assist how can l fix this error code
