Evening all,
I’m in the process of changing the timing belt on the C5.
The belt is changed and tensioned but I’m struggling to find the torque settings for the water pump bolts, the idlers, tensioners, etc. There’s nothing at all about them in the pages from the workshop manual I have.
Does anyone know where I can find the torque settings?
Thanks,
David.
C5 3.0 HDI Torque Figures
DHallworth
- x 167
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6956
Re: C5 3.0 HDI Torque Figures
Here you go:
| Reference | Designation | Tightening procedure |
| (1) | Bolts - Camshaft Pulleys | Tightening torque to 2,3 da.Nm |
| (2) | Camshaft Pulley Hub Screws | Tightening torque to 8 da.Nm |
| (2) | Camshaft Pulley Hub Screws | Angular tightening to 90° |
| (3) | Timing Belt Idler Roller Bolt | Tightening torque to 4,5 da.Nm |
| (4) | Camshaft Timing Chain Tensioner Bolt | Tightening torque to 0,9 da.Nm |
| (5) | Camshaft Bearing Bolts (*) | Pre-tighten to 0,5 daNm |
| (5) | Camshaft Bearing Bolts (*) | Tightening torque to 0,9 da.Nm |
| (6) | Screw Fixing The Timing Pinion To The Crankshaft | Tightening torque to 30 da.Nm |
| (6) | Screw Fixing The Timing Pinion To The Crankshaft | Angular tightening to 90° |
| (7) | Timing Belt Tensioner Roller Bolt | Tightening torque to 2,6 da.Nm |
DHallworth
- x 167
Amazing, thank you very much!
That’s great peace of mind.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
- x 167
If I could be really cheeky, you don’t have the tightening sequence and torque figures for the sump bolts, do you?
Thanks,
David.
Thanks,
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6956
I just realised I missed off the timing Cover...
| (8) | nut - Timing cover | Tightening torque to 0,9 da.Nm |
| (9) | bolts M6x36 - Timing cover | Tightening torque to 0,9 da.Nm |
| (10) | bolts M6x30 - Timing cover | Tightening torque to 0,9 da.Nm |
| (11) | bolts M6x32 - Timing cover | Tightening torque to 0,9 da.Nm |
| (1) | Bolts - Oil Pump (*) | Pre-tighten to 0,4 daNm |
| (1) | Bolts - Oil Pump (*) | Tightening torque to 0,9 da.Nm |
| (2) | Oil Level Sensor | Tightening torque to 2,7 da.Nm |
| (3) | Bolts M8 - Engine Sump (*) | Pre-tighten to 1 daNm |
| (3) | Bolts M8 - Engine Sump (*) | Tightening torque to 2,3 da.Nm |
| (4) | Bolts M6 - Engine Sump (*) | Pre-tighten to 0,4 daNm |
| (4) | Bolts M6 - Engine Sump (*) | Tightening torque to 0,9 da.Nm |
| (5) | Oil Suction Strainer | Tightening torque to 0,9 da.Nm |
| (6) | Bolts - Sump (*) | Pre-tightening to 0,4 da.Nm |
| (6) | Bolts - Sump (*) | Tightening torque to 0,9 da.Nm |
| (7) | Drain Plug | Tightening torque to 2,3 da.Nm |
| (8) | Lower Dipstick Guide Tube | Tightening torque to 0,9 da.Nm |
| (9) | Oil Deflector | Tightening torque to 0,9 da.Nm |
| (10) | Piston Skirt Spray Jets | Tightening torque to 1 da.Nm |
DHallworth
- x 167
Thank you Marc, really appreciate your help as always.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
