C5 3.0 HDI Torque Figures
DHallworth
x 171
Unread post by DHallworth »
Evening all,
I’m in the process of changing the timing belt on the C5.
The belt is changed and tensioned but I’m struggling to find the torque settings for the water pump bolts, the idlers, tensioners, etc. There’s nothing at all about them in the pages from the workshop manual I have.
Does anyone know where I can find the torque settings?
Thanks,
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
x 6950
Re: C5 3.0 HDI Torque Figures
Here you go:
ReferenceDesignationTightening procedure
(1)Bolts - Camshaft PulleysTightening torque to 2,3 da.Nm
(2)Camshaft Pulley Hub ScrewsTightening torque to 8 da.Nm
(2)Camshaft Pulley Hub ScrewsAngular tightening to 90°
(3)Timing Belt Idler Roller BoltTightening torque to 4,5 da.Nm
(4)Camshaft Timing Chain Tensioner BoltTightening torque to 0,9 da.Nm
(5)Camshaft Bearing Bolts (*)Pre-tighten to 0,5 daNm
(5)Camshaft Bearing Bolts (*)Tightening torque to 0,9 da.Nm
(6)Screw Fixing The Timing Pinion To The CrankshaftTightening torque to 30 da.Nm
(6)Screw Fixing The Timing Pinion To The CrankshaftAngular tightening to 90°
(7)Timing Belt Tensioner Roller BoltTightening torque to 2,6 da.Nm
DHallworth
x 171
Amazing, thank you very much!
That’s great peace of mind.
David.
DHallworth
x 171
If I could be really cheeky, you don’t have the tightening sequence and torque figures for the sump bolts, do you?
Thanks,
David.
x 6950
I just realised I missed off the timing Cover...
(8)nut - Timing coverTightening torque to 0,9 da.Nm
(9)bolts M6x36 - Timing coverTightening torque to 0,9 da.Nm
(10)bolts M6x30 - Timing coverTightening torque to 0,9 da.Nm
(11)bolts M6x32 - Timing coverTightening torque to 0,9 da.Nm
(1)Bolts - Oil Pump (*)Pre-tighten to 0,4 daNm
(1)Bolts - Oil Pump (*)Tightening torque to 0,9 da.Nm
(2)Oil Level SensorTightening torque to 2,7 da.Nm
(3)Bolts M8 - Engine Sump (*)Pre-tighten to 1 daNm
(3)Bolts M8 - Engine Sump (*)Tightening torque to 2,3 da.Nm
(4)Bolts M6 - Engine Sump (*)Pre-tighten to 0,4 daNm
(4)Bolts M6 - Engine Sump (*)Tightening torque to 0,9 da.Nm
(5)Oil Suction StrainerTightening torque to 0,9 da.Nm
(6)Bolts - Sump (*)Pre-tightening to 0,4 da.Nm
(6)Bolts - Sump (*)Tightening torque to 0,9 da.Nm
(7)Drain PlugTightening torque to 2,3 da.Nm
(8)Lower Dipstick Guide TubeTightening torque to 0,9 da.Nm
(9)Oil DeflectorTightening torque to 0,9 da.Nm
(10)Piston Skirt Spray JetsTightening torque to 1 da.Nm
DHallworth
x 171
Thank you Marc, really appreciate your help as always.
David.
