Automatic Gear selector Mechanism
- x 8130
My C5 gear selector has a simple issue which is that the spring loaded detent in the mechanism, which acts against the selector cover to hold the gearstick in position, has broken and pings out as the lever is put into park. Is there an exploded view of the mechanism showing the ball topped detent and its spring?
- x 6945
Re: Automatic Gear selector Mechanism
Here you go Mick:
Is this the part you want:
- x 8130
Thanks Marc, It would appear from that diagram that the part I need is number 10 and comes as a complete housing with the detent installed. Any chance of a part number for it or is it discontinued? Cheers
- x 6945
Item (10) is called the Hardness Tester (?)
Part number is 240778 and is £11.41 from Citroen inc. VAT - still showing as available.
- x 8130
Excellent!! Thanks Marc I'll order one and we'll see what happens
- x 8130
Sorry to be a complete pain Marc by I cannot find a link in any citroen websites or my dealer website to order the part. Any ideas?
- x 6945
No, you can't Mick - you need to contact your local Citroen or Peugeot dealership and ask for Parts (or they may have another option if parts are not operating at present with lockdown). They can take payment over the phone as it will be an order in item. You'll then have to arrange to collect it via whatever procedures they have in place.
- x 8130
Ok thanks Marc, much appreciated, I'll get onto that in the morning then.
Milordas
I don't know if I have the same problem, but almost every time when I'm pushing the lever from park its making clicking noise. I removed the cover and noticed that some plastic part is broken and moves to the right when I try to move from park. Anybody knows what might cause this?
The link for the clicking noise and the broken part: https://drive.google.com/drive/folders/ ... sp=sharing
