Loss of power - phantom fault
DS3XBCk
Unread post by DS3XBCk »
I wonder if anyone could help me.
Twice I have been driving my DS3 crossback and it has lost power (limp mode) and the engine fault light has come on. This has happened twice about 4 months apart.
The first time breakdown came and then had to tow it back to my garage and the second time, (today) I luckily happened to be close to the garage, so I could drive it there.
The garage read the code but the diagnostic report came back as
status: intermittent
description: configuration fault (warning! This may be a phantom fault).
They said the car ‘computer’ had to be reset. They did this and it is working fine now.
A few days ago my ‘low oil warning light’ came on, I topped it up and it went off.
The guy at the garage said the engine fault light could have been related to that and just messed up the system.
Has anyone else experienced this or have any advice.
Thanks in advance.
x 6962
Re: Loss of power - phantom fault
How old is the vehicle? These have only been out since 2019, so if it's still within warranty, take it back to the dealer.
You haven't mentioned what engine this is, better still if you have the VIN it will save me asking more questions (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
DS3XBCk
Thanks for your reply.
The vehicle is a 69 plate. Sadly, just out of warranty.
The dealer that I bought it from isn’t far from me but the nearest main DS garage/dealer is over 100 miles away!
1199 PETROL 2020 Performance Line automatic
VR1**************[VIN obfuscated, can be read by forum staff]
x 6962
Ok so for reference you a DS 3 CROSSBACK (D34) 5-DOOR CROSS OVER 1.2 PureTech 130 (EB2ADTS Euro 6.3) STT TYPE 8-SPEED AUTOMATIC GEARBOX
Unfortunately the engine warning lamp can have multiple reasons for illuminating and the cause will be accompanied by fault specific codes. If you get the actual fault codes from your garage this may help.
DS3XBCk
Thank you that’s it.
Not sure if this is a fault code: B1003:00
DS3XBCk
Diagnostic report
Diagnostic report
x 6962
Ok, so your mechanic is not using Diagbox which is recommended for proper fault finding as these vehicles have lots of tech that a lot of aftermarket diagnostic tools can't read, just so you know.
This fault is basically stating that the BSI has not completed a configuration properly - this can be caused if the BSI software has been updated at the dealership previously and it has not been fully completed. Sometimes it can take a few attempts for the update to save correctly.
Fault Code: B1003 00
Description of Fault: Configuration fault. Configuration procedure interrupted or incomplete.
Conditions of activation of the diagnostics
Possibility 1
The following conditions have to be met
- Vehicle stationary
- Ignition on
- Vehicle not in economy mode
Possibility 2
- Engine running
Conditions for Fault to clear: The configuration has been carried out successfully.
Downgrade Modes whilst Fault is active: -
Symptoms:
  • Activation / Deactivation of the obstacle detection impossible
    If you need an oriMalfunction of the obstacle detection
  • Problem turning the audio system on/off
  • Malfunction of the buttons and/or controls of the audio system
  • Problem inserting, ejecting a CD or an SD card (According to equipment)
  • Problem accessing the telematic services
Suspect Areas: Configuration of the built-in systems interface
DS3XBCk
Thanks so much for this info.
I did actually get an update back in January and haven’t had any problems since with the loss of power- until today :(
The only problems I’ve had is the sat nav screen not always coming on and the windscreen and back window heaters and heating system buttons not working. Very odd things.
I’ll have to get on to the DS dealer with this info and get it booked in again. Just a shame it’s 100 miles away. There aren’t many DS dealerships in England , all spread out. :shock:
x 6962
Well all those issues you are experiencing are pointing to the BSI and until this is corrected you will continue to have failures and odd behaviour most likely.
If you reported this to them before when it was under warranty and they looked at it - then I would argue the case that it has never been resolved and has now led to things getting worse if the same fault was coming up. They would have a record of it I suspect. Once thing is certain you can't go on with it like this as you may have a more severe impact of the system failing.
DS3XBCk
Agree.. I better get onto them.
Thank you for your help and advice.
DS3XBCk
Sorry just one more question.. as the car ‘had’ its update in January and it’s out of warranty now, do you think they would charge me for this update? Any idea of how much these updates are?
I just hope they say they will do it again free of charge, if it wasn’t completed properly.
Many thanks
DS3XBCk
I got in touch with them- sadly they can’t book me in until June but at least its booked in. I’ll have to try and avoid motorways until then!
The guy said it certainly sounds like it could be an update issue.
They said it should be free if it’s related to the previous update, otherwise it will be £144!
So I’ll have to wait and see!
Thanks so much for your help and advice Marc.
Have a good day!
x 6962
Hi, yes the £144 is the standard diagnostics charge, which should cover any software updates. I wasn't aware until your last post that it had been in for an update, but certainly sounds like they have confirmed this, so I suspect is where you problem is. Just keep a record of everything.
DS3XBCk
Yes, it went in for an update in January. It had lost power (limp mode) once before the update in January. Had to have it towed to my local garage and they ran a test on it and couldn’t find anything.
Lost power (limp mode) again on Thursday, and there has been lots of strange things happening since the ‘update’ in January- buttons not working, boot not opening, satnav screen not coming on, limp mode.
So, booked in for a second time now in June to hopefully complete the update successfully this time so these problems won’t continue. [-o<
Cheers
