You obviously aren't using live data as some of it seems to be 9 years old, as a lot of those part numbers have been replaced now... so be aware.perrye wrote: 04 Mar 2023, 08:07Hirijndael wrote: 03 Mar 2023, 23:29 Hi there, guys,
Is there any way to know in advance (without unmounting one) what material (steel or aluminum) the wishbone front subframes are made of?
If I need to replace them, which ones should I buy, 3520W2 & 3521S5 or 3520X6 & 3521T7 ??
(Sorry if there are any grammar or spelling/ortographical mistakes, I'm not native english speaker)
Thank you for your help!
yes there is, depending your cars DAM/OPR number. For
C5 (X7) 3.0 HDI FAP
3520 W2 WISHBONE FRONT, LEFT Until OPR 11983
3521 S5 WISHBONE FRONT, RIGHT Until OPR 11983
3520 W2 WISHBONE FRONT, LEFT ALUMINIUM SUBFRAME WITH FRAME And Since OPR 11984
3520 X6 WISHBONE FRONT, LEFT STEEL SUBFRAME WITH FRAME And Since OPR 11984
3521 S5 WISHBONE FRONT, RIGHT ALUMINIUM SUBFRAME WITH FRAME And Since OPR 11984
3521 T7 WISHBONE FRONT, RIGHT STEEL SUBFRAME WITH FRAME And Since OPR 11984
C5 X7 Lower Rear Bush Replace
- x 6945
Re: C5 X7 Lower Rear Bush Replace
rijndael
Hi Marc,
Can you help me with the main question?
How could I know which part numbers I should buy (and current PNs)? Steel or aluminum (for OPR >11984)?
Thank you!
Thank you!
- x 6945
We can help with official live part numbers from Citroen, but please read the first post of the Parts Thread here:
viewtopic.php?p=685750#p685750
rijndael
Hi Marc,
Thank you.
Then, it seems you expect that I read 68 pages to find the answer to my main question... Is that correct??
Thank you.
- x 1938
No, he's asking you to read the first post. That details the fact that PSA charge for access to their parts number database. And that includes this forum. The forum pays for access to this database but we ask members who then need part numbers to donate to the forum in turn.
This is then valid for up to two years. £10 is the minimum but you can pay more if you like.
rijndael
Thank you Paul-R.
You're right, that's what Marc said. Sorry.
Apart of that question about PN, regarding the other question about the material (steel or aluminum), is there a clear response? Can we say that I should buy the steel ones?
Thanks!
Thanks!
- x 6945
To determine that, we would need to check your vehicle specification requiring a parts look up from your VIN, which is why I referred you to the parts thread.
