Check and Regulate C5 Mk1 Suspention
yoseff
x 30
Unread post by yoseff »
Today i was trying to regulate my C5 heights , but i confess i got a bit confused relating to what should be manually done and how to get the numbers to put in Diagbox.
I found this topic viewtopic.php?p=564318#p564318 for Mk2 but found none for MK1
Also other thing that is confusing me is that for the front , In Lexia it says to get the number by doing 280 - (R1+H1M) , but on the other topic for the MK2 it says 280 - (R1-H1M).
In my case it should be wrong , but the numbers are 280-(300-148) , and it says after put the number that it is out of tolerance...
I guess i need some enlightenment on the complete process :mrgreen:
x 6955
Re: Check and Regulate C5 Mk1 Suspention
Mark I C5 Height Calculation here:
viewtopic.php?p=583285#p583285
yoseff
x 30
GiveMeABreak wrote: 27 Feb 2023, 23:47 Mark I C5 Height Calculation here:
Thanks for pointing direction. It was of great help. Now i have the car with perfect height. It is way more stable and comfy. Not perfect yet , (regarding to comfort) , but i'm pretty sure spheres are with lower pressures than it was supposed. Need to test them , but dont have a sphere tester yet. Need to build one, possibly with some Xantia spare parts i have around.
The main problem was that even in Diagbox it was showing wrong instructions on how to get the number to put there , saying it would be 280-R1+H1M... Anyway , thanks to your info , i was able to set the proper Heights.
One less thing to worry on the 2.2. On to the next problem :mrgreen:
yoseff
x 30
By the way... Does anyone has an Hub Centre tool that we could get measurements in order to be easier replicate the original on a 3D printer? That would be awesome , as the finding of radius is a bit more complex than it appears...
x 6955
These aren't available that I can see as they are special tools. Best bet is to improvise and use the centre of a wheel cap to mark the centre with a marker or similar.
