Paint code?? I can't find it
Theflyingpostman
- x 3
I have AX is white, I have look for the code is only one on the strut top body say 6681, when I go on eBay it does not search result in code numbers but the name of the paint! I am unsure what the colour is call?
https://www.ebay.co.uk/itm/391779242971 ... R_bw6MLVYA
- x 1460
Re: Paint code?? I can't find it
6681 is the build date of your car: February 23, 1995.
The paint code should be somewhere nearby, similarly stencilled in the format xyz-ab where xyz is the paint code and ab is the factory code.
Theflyingpostman
- x 3
- x 6945
Your paint code is:
EWP - BANQUISE WHITE PAINT
citroC5
- x 20
Do you mind if I ask how you sussed that out? I've been looking for my wife's AX's paint code and I can't find it
- x 8406
On an S1 AX you'll find it stencilled on the RH inner wing between the strut tower and the washer reservoir filler neck..
Here's mine:
On later cars, it can be partially obscured by the engine ECU...
Here's mine:
- x 1055
The paint code can be obtained from the VIN on servicebox if you cant see it on the bodywork.citroC5 wrote: 22 Feb 2023, 16:59 Do you mind if I ask how you sussed that out? I've been looking for my wife's AX's paint code and I can't find it
citroC5
- x 20
Terribly sorry, but do you need to be registered to access servicebox?wheeler wrote: 22 Feb 2023, 17:50 The paint code can be obtained from the VIN on servicebox if you cant see it on the bodywork.
- x 1489
You have to pay for servicebox, but we have a subscription, and since you're a current donor we dan look it up for you if you post the VIN.
- x 6945
If it's for your C5 VIN ending in 169, then your paint code is:
KGN - BOURRASQUE PAINT
citroC5
- x 20
Thank you, Richard. It's for my wife's AX.RichardW wrote: 25 Feb 2023, 12:30 You have to pay for servicebox, but we have a subscription, and since you're a current donor we dan look it up for you if you post the VIN.
The vin number is VF7**************[VIN obfuscated, can be read by forum staff]
citroC5
- x 20
Thanks anyway, fortunately the sticker on the B-pillar is still intact!GiveMeABreak wrote: 25 Feb 2023, 12:55If it's for your C5 VIN ending in 169, then your paint code is:
- x 1489
Sadly info not recorded for that car, it does tell us that the upholstery colour is FZ....
- x 1460
If you post a nice picture of the car, (and the year of manufacture) we can probably work it out, as Citroen only used a limited range of colours at any one time.citroC5 wrote: 25 Feb 2023, 19:11 . It's for my wife's AX.
- x 8406
And look at my last post in this thread for the AX paint code location and from that we can advise what colour it isxantia_v6 wrote: 25 Feb 2023, 23:36If you post a nice picture of the car, (and the year of manufacture) we can probably work it out, as Citroen only used a limited range of colours at any one time.citroC5 wrote: 25 Feb 2023, 19:11 . It's for my wife's AX.
The vin number is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
