Paint code?? I can't find it
Theflyingpostman
x 3
Unread post by Theflyingpostman »
I have AX is white, I have look for the code is only one on the strut top body say 6681, when I go on eBay it does not search result in code numbers but the name of the paint! I am unsure what the colour is call?
https://www.ebay.co.uk/itm/391779242971 ... R_bw6MLVYA
x 1438
Re: Paint code?? I can't find it
Unread post by xantia_v6 »
6681 is the build date of your car: February 23, 1995.
The paint code should be somewhere nearby, similarly stencilled in the format xyz-ab where xyz is the paint code and ab is the factory code.
Theflyingpostman
x 3
I am not sure which to look for? See my pictures.
x 6953
Your paint code is:
EWP - BANQUISE WHITE PAINT
citroC5
x 20
Unread post by citroC5 »
Do you mind if I ask how you sussed that out? I've been looking for my wife's AX's paint code and I can't find it
x 8272
On an S1 AX you'll find it stencilled on the RH inner wing between the strut tower and the washer reservoir filler neck..
Here's mine:
On later cars, it can be partially obscured by the engine ECU...
x 1055
Unread post by wheeler »
citroC5 wrote: 22 Feb 2023, 16:59 Do you mind if I ask how you sussed that out? I've been looking for my wife's AX's paint code and I can't find it
The paint code can be obtained from the VIN on servicebox if you cant see it on the bodywork.
citroC5
x 20
wheeler wrote: 22 Feb 2023, 17:50 The paint code can be obtained from the VIN on servicebox if you cant see it on the bodywork.
Terribly sorry, but do you need to be registered to access servicebox?
x 1477
You have to pay for servicebox, but we have a subscription, and since you're a current donor we dan look it up for you if you post the VIN.
x 6953
citroC5 wrote: 25 Feb 2023, 12:26
If it's for your C5 VIN ending in 169, then your paint code is:
KGN - BOURRASQUE PAINT
citroC5
x 20
RichardW wrote: 25 Feb 2023, 12:30 You have to pay for servicebox, but we have a subscription, and since you're a current donor we dan look it up for you if you post the VIN.
Thank you, Richard. It's for my wife's AX.
The vin number is VF7**************[VIN obfuscated, can be read by forum staff]
citroC5
x 20
GiveMeABreak wrote: 25 Feb 2023, 12:55
Thanks anyway, fortunately the sticker on the B-pillar is still intact!
x 1477
Sadly info not recorded for that car, it does tell us that the upholstery colour is FZ....🤨
x 1438
citroC5 wrote: 25 Feb 2023, 19:11 . It's for my wife's AX.
If you post a nice picture of the car, (and the year of manufacture) we can probably work it out, as Citroen only used a limited range of colours at any one time.
x 8272
xantia_v6 wrote: 25 Feb 2023, 23:36
The vin number is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
And look at my last post in this thread for the AX paint code location and from that we can advise what colour it is ;)
