Hi all,
Been reading around what I could find, none the wiser at present whether there's anything to be concerned about...
Very recently acquired a high mileage but VERY well cared for 2003 307 1.6 16v, petrol.
Clean and tidy, fully serviced etc. I've been sorting a few minor issues. The car starts and runs brilliantly - the MOT last week made zero mention of emissions - indeed there are none. At idle it's nearly impossible to hear engine noise at all. At driving speeds it's nearly all just tyre/road noise.
Only when I'm in 5th gear, and only when on the throttle, or under load i.e. going up an incline, there's just the tiniest of whining noises from the right hand side. If I lift off the throttle it disappears. If I press the clutch pedal while moving the noise disappears.
It may be nothing, this is about prevention and getting ahead of any potential issue before one should occur. Since this is the only more "modern" Peugeot I've owned I have no reference. What say wise minds here?
307 Mk 1: mild (very mild) whine in 5th gear
alan9990
- New User
- x 8378
Re: 307 Mk 1: mild (very mild) whine in 5th gear
Welcome to the forum Alan
The very first thing I'd do is change the gearbox oil - make sure you use the right stuff as PSA gearboxes are fussy in this respect... I would expect it needs around two litres of 75w/80. Maybe someone can confirm... If so, I recommend Total BV as this is the OE lubricant.
The level may be low and it's possible the fifth gear pinions have been very slightly starved of lubricant as if your 'box is like the earlier ones, the 5th gear pinions are right out on the end, just beyond the main casing and likely to be the first to suffer if the oil level is low..
I had this same issue on my AX and although an oil change has not 100% cured it, kit is reducing with each run...
I've known similar gearboxes run so low on oil as to be practically dry. They are tough old beasts and will survive for a long time like this and not really obviously complain...
So get that oil changed as a first move
Fingers crossed it sorts it...
- x 2341
From 307 Haynes manual (4147)CitroJim wrote: 23 Feb 2023, 17:36 gearbox oil - make sure you use the right stuff as PSA gearboxes are fussy in this respect... I would expect it needs around two litres of 75w/80. Maybe someone can confirm... If so, I recommend Total BV as this is the OE lubricant.
1.6 is MA5 gearbox, capacity 2.0 litres
"SAE 75W-80W (which is a typo, think should read 75W80, no second W!!) To API GL5 specification: ESSO gear oil BV or Total Transmission BV"
- x 2341
P.s. come and join the gearbox oil discussion here, especially if you do a change and can report back if made a difference
viewtopic.php?t=73661
I think it's mentioned on there, I'm currently using some fully synthetic GL5 75W80 spec stuff, bought off eBay. Westway lubricants I think. Not tried it in a MA gearbox yet (BE4 and ML6 both happy with it)
- x 1940
I may be be completely misremembering this but isn't the GL5 spec disallowed and you should use GL4?
- x 2341
Oh! Don't know!Paul-R wrote: 23 Feb 2023, 20:08 I may be be completely misremembering this but isn't the GL5 spec disallowed and you should use GL4?
Just double checked, Haynes 307 manual: Whilst I am having a look,
306 manual says:
406 Haynes says:
But googling Total Transmission BV, gives Total Traxium and that seems to be GL4
https://www.ebay.co.uk/itm/403460989313 ... media=COPY
Confusing!
- x 3306
You DO remember the nickname for Haynes, don't you?
- x 2341
And to round it off, but sadly not to bring it to a conclusion,
Haynes Citroen C4 manual (5576) 2004-2010
Oh I know the Book Of Lies isn't a great reference, but they are cheap (2nd hand) and help dry oily fingers a treat
