Change language RT3
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
Sameh Jaziri
Re: Change language
Unread post by Sameh Jaziri »
Hello, I have a Citroen c5 2005 V6 and I have the same request, How can I change language to English
x 6948
Re: Change language
This has already been answered, please read the previous posts:
viewtopic.php?p=691166#p691166
Sameh Jaziri
Re: Change language
x 6948
Re: Change language
@Sameh Jaziri: Ok so I assume you also need the firmware. Check your Private Messages.
Kangze
Re: Change language RT3
Unread post by Kangze »
Hello,
I would like to ask for your help too.
I have a 2006 Fiat Ulysse from Austria.
I would like to change the language from german to english, but it keeps asking for the cd, what I do not have unfortunately.
I guess the system is RT3 CAN, Firmware 6.61.
(It has navigation, but the display is the smaller one. At the moment the display does not work properly, but I'll fix it soon)
Thank you very much for your help in adcance.
I'm waiting for yor reply.
tarbeni
Unread post by tarbeni »
Hi, I have the same problem. I want to change the language from German to English.
Can I get a copy of the CD too? :)
(It's an older photo, I had to change the screen unit and now the language is German)
x 6948
@Kangze
@tarbeni
htdhh
Unread post by htdhh »
Hello !
@GiveMeABreak
Im having the same problem, I have a 2005 Citroen C5 bought from Germany that has the menu in german, and when I try to change it, it gives the same message, "Insert CD drive"
Did you manage to solve your problem ? Im not sure how to check what nav system my car is using.
However i grabbed the same information shown in "Geratebeschreibung", that I hope would help :
Steuergerate-Nr. 9661450777
Display-Nr. 9661552580
Soft-Version Steuerge 6.61
Soft-Version Display C30CD 1C35
Thanks in advance!
x 6948
Check your private messages
deniz
Unread post by deniz »
Hello, I have a2006 C4, Ihave the same problem. I want to change the language from German to English.
Can I get a copy of the CD too? Thank You
Srteuergerate -Nr : 966 1450277
Display -Nr: 966 1552 180
Soft -Version Steuerge 6.63
Soft-Version Display: C30CEOC35
x 6948
@deniz: Check your Private Messages.
Kunigaikstis
Unread post by Kunigaikstis »
Hello. Sorry for necroposting but I have the same issue.
My car is a C5 RCRHRH
Here is a screenshot with the relative info.
I know how to handle ISO files so that will not be a problem
x 6948
@Kunigaikstis: Check your Private Messages.
temelkovski
Unread post by temelkovski »
Hello, i need a firmware update CD (or ISO) for my car that i just bought.
Car is : Peugeot 307, 1.6 16V and is from 2006.
I need this CD to change language from Nederland to English, so i can understand something.
Can you please help me?
I would be very grateful, thanks in advance!
x 6948
