Engine mount , this looks iffy
Huskyxantia
x 844
Re: Engine mount , this looks iffy
Unread post by Huskyxantia »
MattBLancs wrote: 05 Feb 2023, 17:02 Here's a picture of a 307 2.0 petrol lower mount. Looks similar to me Image
Cool , when i saw that gap i flipped !
:-D
x 5634
Worth trying some Forté "Cooling System Stop Leak" maybe.
Can be difficult to get locally but eBay and Amazon have it.
Doesn't clog waterways like some others are prone to do.
x 2297
Unread post by MattBLancs »
myglaren wrote: 05 Feb 2023, 17:14 Worth trying some Forté "Cooling System Stop Leak" maybe.
Yes the clogging is what worries me. I'll research how easily the matrix comes out , as Huskyxantia says, I think you can see at least the edge of its housing below the glovebox, so might be less involved to get at than I fear (if you listen carefully, you might just heat the underlying "please, please, please, PLEASE" there!)
Huskyxantia
x 844
MattBLancs wrote: 05 Feb 2023, 19:46
Here Matt have a look
:-D
x 2297
Huskyxantia wrote: 05 Feb 2023, 19:53 Here Matt have a look
Brilliant! Wow, remarkably straight forward!
This is same job in a 306
http://www.306gti6.com/forum/showthread.php?id=168346
(Not my picture, but have read up on this previously)
So you can understand why I was filled with dread! :-D
I'll wait for autodoc's latest one off never to be repeated though actually very similar to last Monday sale tomorrow and likely get a matrix ordered.
Huskyxantia
x 844
Matt, I'm a 50 yr old man with an autistic brain, diagnosed 4 yr ago answered why i was always in trouble at school and growing up in general, i find if you think about a job on a car to much or to hard it jumbles up the reality of how straight forwards some jobs are . Id like to follow your task if you manage to photo diary what you do and post on here, that a be great .
:-D
x 5634
A long time ago I worked with a bloke with a 306 who changed the heater matrix.
The matrix was the easy bit, dismantling everything to get to it then reassembling it all took three days.
Forewarned I let the garage do my Xantia matrix, well worth the £180 it cost.
If you are concerned about clogging, then a shot of Forté cooling system flush may be called for. Alternatively there is Liquimolly that Chris (White Exec) swears by.
x 2297
Huskyxantia wrote: 05 Feb 2023, 20:38 Matt, I'm a 50 yr old man with an autistic brain, diagnosed 4 yr ago answered why i was always in trouble at school and growing up in general, i find if you think about a job on a car to much or to hard it jumbles up the reality of how straight forwards some jobs are . Id like to follow your task if you manage to photo diary what you do and post on here, that a be great .
Would be my pleasure :-D
x 2297
myglaren wrote: 05 Feb 2023, 20:52 A long time ago I worked with a bloke with a 306 who changed the heater matrix.
I've given that video a watch and will change matrix. I also have a thermostat / temperature sensor/ coolant manifold plastic lump to fit, so will do a coolant change (as it's been in more that 5 years I think) and the two jobs together. If the car will tolerate light use till the weather puts another few degrees on preferably!
To be honest it's been loosing coolant very, very slowly for a while, so this is good news as been unable to find any leak evidence, just a drop in level.
Good news, and also something else on the job list, hey ho!
x 3282
I recall that if you were fitting a replacement Valeo heater matrix you had to also use Forté Stop Leak (to fill any micro leaks at the fittings) for them to consider their warranty to be valid.
Huskyxantia
x 844
My tensioner pulley is coming to the end of its service life now ,its bouncing like mad and the noise has got worse over the last 3 weeks, always something ! Good luck with the matrix matt.
:-D
x 8263
Hell Razor5543 wrote: 05 Feb 2023, 21:38 I recall that if you were fitting a replacement Valeo heater matrix you had to also use Forté Stop Leak (to fill any micro leaks at the fittings) for them to consider their warranty to be valid.
Yes, you are quite right James :D I last used it in my Saxo when I could just smell a slight whiff of coolant when the heater was on full hot and it's been perfect ever since...
As a veteran of many Xantia heater matrixes, it's just a long, tedious job taking all the dash apart and putting it all back together again... Not technically difficult at all but you do need to be well organised and methodical to ensure all goes back together exactly as it came apart and no screws are left over at the end ;)
Give yourself plenty of time and enlist some help as the dash itself is surprisingly heavy and awkward to manoeuvre single-handed..
Just to add as a late confirmation, your lower mount looks in good, serviceable condition to my eye Husky... They are designed like that deliberately to have more 'give' in one axis and less in the other...
Huskyxantia
x 844
Thanks Jim . When i saw the size of the gap from part to car body my gut turned over lol
:-D
Huskyxantia
x 844
And another page to this cars life , the front tracking was out 5mm ns the passenger side was ok , new tyres after tie rods and lower ball joints and a tracking recheck done first. Camber at the rear looks ok but i will check that too . Its a pity the back can't be adjusted but i reckon there must be some way because there is always a way isnt there, now then hermes get a b*@^#_÷£$ move on with my tie rods ive got everything else !
:-D
