I've been reading around the forum for a few weeks now, after buying an estate C5 X7 at the beginning of December.
I've got an issue with the suspension, which just isn't as comfortable as it should be. But contrary to many posters here, it's the rear end that looks visually too high, not the front.
Going over long speed bumps, my wife in the back (with new baby) says it's unbelievably uncomfortable coming down from the bump, with it feeling like the wheels drop first, then the body follows. A bit of a thump (especially with something loose in the boot) can be heard.
When the car is at a standstill on my drive, the rear is visibly higher than the front - front end gap between tyre and wing seems fine, the rear looks like it's an SUV almost.
With a very unprofessonal tape-measure measurement, it seems the rear is ~2cm higher off the ground than the front, with the front being ~41-41,5cm center of wheel to wing, while the rear is at ~43,5 for the same measurement.
Motion seems fine, with the car dropping low and coming back to normal without issue (I read that some people with height sensor issues have trouble raising it back from the bottom).
What could be the places to look for the problem?
