C5 X7 no start (or only runs for fraction of a second)
- x 2356
Re: C5 X7 no start (or only runs for fraction of a second)
The 406 Coupe (and indeed saloon and estate, if not fitted with the big rear drums) handbrake is pretty rubbish so came in handy reflex for that!
moizeau
- x 423
MattBLancs wrote: 30 Dec 2022, 07:02 The 406 Coupe (and indeed saloon and estate, if not fitted with the big rear drums) handbrake is pretty rubbish so came in handy reflex for that!
The wonderful idea of having a drum on the inside of the disc....
Pete
- x 2356
Yes, it's got all the disadvantages of both!
There's others do it (I've seen a BMW in bits that had same arrangement, with the added joy of a driveshaft through the middle of it - looked even less fun to fix!)
Often wondered about conversion to normal (e.g. 306) rear handbrake calipers
- x 8420
Liquid lunches and Friday afternoons have a lot to answer for...
H4wkeye
- x 14
Probably the colder weather I assume. Friend's battery died on his 307 1.6 HDI a few weeks ago as well. Winter wonders as they say!MattBLancs wrote: 29 Dec 2022, 19:17Just to summarise earlier waffling:H4wkeye wrote: 29 Dec 2022, 00:01 Also, I see you have the glow plug code too, so far I didn't notice issues but it hasn't been that cold yet. Coldest I started it at, was at 1c, after sitting for a few days.
Started in -3°C then again the next morning in indicated -5°C with current glow plug fault present= bit lumpy for 1-2 seconds at idle then "cleared it's throat" or, more accurately: began running consistently on all cylinders, and was fine after that.
Interesting the sudden starter motor failures being reported - all interesting stuff!
My starter failure experience thus far was my wife's 206 1.6 HDi = more accurately was a sticking starter. Sometimes no start, sometimes reluctant to let go of the ring gear once it fired up. Second hand starter bought (£12 online or something ridiculous cheap including delivery) that was stripped down, regressed, commutator cleaned, then starter fitted complete= never a problem since. Incidentally DV6 starter (on the rear of the block, above driveshaft) is absolute pig of a job.
In comparison, 2.2 HDi starter, sat on the front, I'm pretty much looking forward to the task!![]()
- x 5672
I had a Volvo 265 with that arrangement. Was easy to deal with and effective.moizeau wrote: 30 Dec 2022, 07:06The wonderful idea of having a drum on the inside of the disc....MattBLancs wrote: 30 Dec 2022, 07:02 The 406 Coupe (and indeed saloon and estate, if not fitted with the big rear drums) handbrake is pretty rubbish so came in handy reflex for that!
- x 2356
New starter motor has arrived. Lucas box, Valeo stamp on its casing.
Unfortunately rain has also arrived (and 206 still in bits too!)
- x 8420
Fingers crossed the rain soon stops and the starter motor does the trick Matt
- x 2356
Weather did improve but was busy with 206 related activities, mentioned here:CitroJim wrote: 30 Dec 2022, 15:35 Fingers crossed the rain soon stops and the starter motor does the trick Matt![]()
viewtopic.php?t=73096
And
viewtopic.php?t=72949&start=60
And other bits of faffing I can't bring to mind at moment!
ciaranwebb0
Hi guys! I’ve no idea how I stumbled on this thread but I thought I’d add my experience to see if it’s of any help. I have exactly the same drivetrain (2.2 HDI 173) in a 2009 C5 tourer although a VTR+. Funnily enough I had exactly the same symptoms - it cranks and sounds like it fires momentarily but then seemingly cuts fuel supply. Could not for the life of me figure out why - the fuel side of things seemed absolutely fine.
I bought the car second hand on eBay and the cam belt had never been done. On doing the cam belt, my mechanic had re-routed the loom that connects with the cam position sensor and had it under tension (it is located very near the timing cover). Although I couldn’t find this online anywhere, if it cannot sync the crankshaft position with the camshaft position it will not allow fuel to be delivered to the injectors. I was under the impression that it only needed a crankshaft position to start the engine but it needs both. I had no codes for this though, after hours of frustration with priming the fuel pump I saw the cables going into the position sensor were under strain and loose. I managed to jiggle and tape up the connector until I got it permanently fixed, and it turned out I also needed a new camshaft position sensor too. No problem with starting since then and that was all done in 2021. I’m sure you’ve checked but might be worth a try.
Cheers,
Ciaran
Cheers,
Ciaran
- x 2356
Hi Ciaran,ciaranwebb0 wrote: 30 Dec 2022, 22:43 Hi guys! I’ve no idea how I stumbled on this thread but I thought I’d add my experience to see if it’s of any help. I have exactly the same drivetrain (2.2 HDI 173) in a 2009 C5 tourer although a VTR+. Funnily enough I had exactly the same symptoms - it cranks and sounds like it fires momentarily but then seemingly cuts fuel supply. Could not for the life of me figure out why - the fuel side of things seemed absolutely fine.
Cheers,
Ciaran
Thanks for joining in with your experiences - always useful. I don't remember touching the camshaft sensor wiring doing the belt change, but will give that area a good check over too.
Crankshaft sensor is very vulnerable, seems ok:
On mine, looking at Diagbox readings it did show crankshaft and camshaft values "synchronised" when cranking, so I was treating that as good news
Odd your wiring issue didn't log a fault, would have thought a "no signal" type fault would be likely. How strange!
I am hoping that it's just a cranking speed issue for me, as struggling to think what's different with starter turning over Vs a bump start, other than engine rotational speed achieved.
Will update this thread when motor fitted and then again in a week/ fortnight (if!!) I can confirm that issue has cleared up.
ciaranwebb0
Fingers crossed! No worries - probably is the starter, it sounds like. Is a little odd that I had no code recorded with a dodgy camshaft sensor - but I did confirm it was iffy by running a multimeter by it and seemed like there was a dead short across it. Perhaps the breakdown lot cleared a code without me noticing. Popped a new sensor in it and instant start
Best of luck!! When you can get them running they’re pretty robust old units these I think.
- x 2356
If you look really closely, you may spot a slight size difference between new (left) and old (right) starters!
Mounting points match up, now to see if I can squeeze this beast in to place!
- x 2356
Was about to give up on the basis it just does not fit.
But it does! just!
But it does! just!
admiral51
- (Donor 2026)
- x 391
And..............................?
Colin
Colin
