DS5 Fuse Allocation for Glove Box
x 6953
Re: DS5 Fuse Allocation for Glove Box
Yes, ignore the Fuse F9 - if your Wife's seat is working then it's likely your pad unit. What about the back rest heated pad - is that not working too?
Mares
x 3
Unread post by Mares »
To be honest I did not know back rest is also heated. If i remember well I never felt heating on that part of seat. I will try heating of passengers seat to check what parts of seat is heating. Can you just tell me if F9 should be located in fuse box beneath steering wheel?
x 6953
Fuse F9 is where I showed you in the BFH3 compartment as shown in my previous diagram. But like I said, there's no point in going there because if the fuse was not working you would have no heat on the passenger seat.
Heated seats have 2 pads shown at (12) and (13), with the temperature sensor under the front seat edge (14).
