Citroen c4 cactus 2019 model gearbox oil topup
Robcon83
Unread post by Robcon83 »
Hi everyone,
This is first post, so I would like to say hi to everyone.
And thanks for having me.
I recently changed my front shock absorbers on my Citroën c4 cactus and unfortunately while doing the passenger side shock, some gearbox oil leaked out from the drive shaft. I would like to top up the oil or change it to make sure the correct quantity is in there.
Would anybody have a drawing or know where the filler cap is located or breather if no filler cap.
Also what is the correct gearbox oil for manual 6 speed gearbox. Is is 75w80 gl4+ ???? Or what oil is best??
Thank you in advance.
Rob
x 6946
Re: Citroen c4 cactus 2019 model gearbox oil topup
Pop your VIN up and I'll check your build date (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff), as the 75W80 oil was for older vehicles. Newer versions have a different recommended oil.
Robcon83
Hi Marc,
Thank you for your reply. This is my VIN number.
x 6946
Ok, so the recommended oil for your build date is: TOTAL TRANSMISSION HBVFE2 75W.
Also, please note that your vehicle is being flagged for a recall! I'd call the dealer and give them your VIN, and they'll be able to tell you what it is for, but it will be free of charge.
Robcon83
Hi Marc,
Could you provide me with the gearbox drawing to show the fill and drain plug location. I will fill up with 1.8 litres correct? 100ml will be left in there once drained. Thanks again.
x 6946
You fill up with 1.7 litres after draining:
Type of gearboxMB6
Oil quantity1,8 ± 0,2 litres
Volume remaining after draining0,1 ± 0,1 litres
Filling volume in aftersales1,7 ± 0,1 litres
I don't have the specific diagram for the MB6 gearbox for this vehicle showing the drain and vent accesses - only the gearbox diagram from replacement parts, which requires a membership upgrade:-
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
