Misty Mornings with 2020 vision
- x 8119
Re: Misty Mornings with 2020 vision
I was a boy scout!!
- x 5674
I use it on compression joints (plumbing) to allow them to be tightened without binding and release easier.mickthemaverick wrote: 31 Dec 2020, 10:51Of course !! Why is there something else it was useful for?Paul-R wrote: 31 Dec 2020, 10:48 Indeed - smearing on battery terminals to prevent corrosion.
That is what you meant, isn't it?![]()
Also on woodscrews and nuts & bolts, depending where they are used, screws wind in a lot easier but even better are more easily removed. On cars I use Coppaslip in preference.
1001 uses.
Not a good idea to apply it to camera lenses though, the trick there is to apply it to a UV filter kept aside for such applications.
No mist here this morning.
- x 7164
That was your 4,999 th post Paul....why not put a celebratory pic on POTD or a Celebratory track On the PE Jukebox.
for your 5,000th
- x 5674
Re: Mistless Morning with Blurred vision
Not a trace of mist. Clear night.
Had a look at 06:30. No mist.
Then 07:30. No mist and still dark.
Fell asleep, woke at 9:00 and this is what it was like. Bins, crap cars but mist conspicuous only by it's absence.
- x 8391
It has a myriad of usesmickthemaverick wrote: 31 Dec 2020, 10:51Of course !! Why is there something else it was useful for?Paul-R wrote: 31 Dec 2020, 10:48 Indeed - smearing on battery terminals to prevent corrosion.
- x 3306
This morning, when I went to collect mum (for her shoulder to be stabbed) the River Kennet had a few wisps of mist, so I got a couple of photos.
- x 7164
Well we filled up 8 pages of this at one time, but nothing since January 2021...
...but today was indeed a misty morning so brace yourselves, a vision-on Tuesday 29th November 2022 celebration gallery from the Falcon.
- x 8391
- x 7164
Thanks Jim, mist has lifted now and a bright crisp clear day with temp 0°C.
. What do you call it...invigorating!
- x 8391
DefinitelyNewcastleFalcon wrote: 29 Nov 2022, 14:58 A bright crisp clear day with temp 0°C.. What do you call it...invigorating!
- x 8391
It's autumn so misty mornings make a return for the 2023 season
During my run this morning
- x 7164
This time of year is almost perfectly summed up by the famous poetic line of John Keats.
"Season of mists and mellow fruitfulness"
and to a lesser extent by the nicely named album from Robin Trower
"long misty days"
Album artwork here
https://www.olsenart.com/misty.html
"long misty days"
Album artwork here
- x 8391
- x 1487
Our local hill, Tinto(*), over the mist on the way to work earlier on the week.
* Apparently the largest summit cairn in the UK, you can see if from afar!
- x 8391
Nice one Richard
Today's early morning view across Bury Field ...
