Hi Lads,
Plugged in with my OBD Scanner it says vehicle speed sensor P0500 and P1351. I take it P1351 is the ghost glow plug fault that has followed C5's around since the MK1. Is P1351 Engine or ABS speed sensor.
Quick Stupid question on diagbox
darbuck
- x 291
- x 6961
Re: Quick Stupid question on diagbox
That's the firmware version and won't help if the hardware is not there - it just won't communicate with the vehicle or will only communicate with some ECUs if lucky.
If you need a later version check out Easydiagnostics - there's also a member discount:
viewtopic.php?t=60112
[Other suppliers are also available]
darbuck
- x 291
cit-rotti
- x 77
yes this exists with China clones - some work with the C5I and C5R (diagnosed with the LEXIA) but do not work well with the C5 X7/C6/Peugeot 307 (diagnosed with the Diagbox).darbuck wrote: 22 Nov 2022, 09:42 Hi Wolfgang it used to work on a MK1 C5 I had but not on this one. I might look at getting a new VCI. thanks
And it's not always whether it's full chip or just 2 chip - I know clones that work perfectly well with 2 chip and full chip for the dustbin. Sometimes there is nothing under the chip caps.
In England I know two decent suppliers:
easy-diagnostik and Lance Myers.
Greetings Wolfgang
darbuck
- x 291
darbuck
- x 291
It Has a full chipset the cable is frayed around the vga kind of cable so ordered a new cable and the diagnostic software from easydiagnostics. if it works great if not I need to buy a new VCI
Darren
darbuck
- x 291
