P13BA ENGINE MANAGEMENT ECU PROBLEM
508c5
x 4
Unread post by 508c5 »
HI,
Peugeot 3008, 2016, 1.6 THP 165 BHP. no evident specific malfunction and no engine light on.
I am getting a reading for P13BA trouble code - I can't find anything about it on the service box (or maybe i am looking in the wrong place) - can anyone shed some light about it ?
being that this is a BMW originated engine, I found that per BMW it is likely related to the camshaft sensor or harness ..
thank you
x 6956
Re: P13BA ENGINE MANAGEMENT ECU PROBLEM
Are you sure that's not a P13BE ? I'm not getting this as a valid fault code.
Maybe if you pop the VIN up for this vehicle I can double check against the exact engine.
508c5
x 4
GiveMeABreak wrote: 30 Aug 2022, 20:08 Are you sure that's not a P13BE ? I'm not getting this as a valid fault code.
thank you, pls. see the attachments
508c5
x 4
https://www.engine-codes.com/p13ba_bmw.html - found this for BMW, which in these engines might mean something I guess, being they are BMW's...
however, I changer the sensor, nothing changed...
re p16a7 - I also changed the "diaphragm" (part in pic, part of the cylinder head cover), nothing changed.
508c5
x 4
Maybe if you pop the CIN up for this vehicle I can double check against the exact engine.
THIS IS THE READ FROM DIAGBOX
508c5
x 4
508c5 wrote: 05 Sep 2022, 16:27
RE oil vapour recirculation circuit HEATER - the turbo hose isn't an original one - maybe this is the cause ?
x 1452
Unread post by xantia_v6 »
508c5 wrote: 05 Sep 2022, 16:38 RE oil vapour recirculation circuit HEATER - the turbo hose isn't an original one - maybe this is the cause ?
That is highly likely. You can probably mask the error by fitting a resistor across the connector, I would start with 50?, but make sure the power rating is sufficient (5W) for 12V applied.
508c5
x 4
xantia_v6 wrote: 05 Sep 2022, 18:02
THANK YOU ! but i didn't understand any of it :rofl2: (don't KNOW anything re electricity..) is there any diagram/pic that can illustrate it ?
I can test it - replace it with the original one I have on my 508 and see if anything changes for the better.
however, i used a non genuine pipe before but never came across this kind of fault.
any clue about the P13BA ??
508c5
x 4
Exchanged between the pipes and after a test drive P16A7 didn't come back
P13BA - still a conundrum
508c5
x 4
Maybe it is related to the VVT ? Would it make sense ?
508c5
x 4
508c5 wrote: 15 Sep 2022, 16:46 Maybe it is related to the VVT ? Would it make sense ?
So...now a P0367 code popped - "Motorized throttle Unit. adaptive at limit" (again, no change in car's behavior) - combining the two maybe indicates (as i suspected) that the VVT valve is not working properly ?
x 6956
P0367 isn't a fault listed under this engine, so I can't provide further detail.
508c5
x 4
GiveMeABreak wrote: 22 Sep 2022, 09:46 P0367 isn't a fault listed under this engine, so I can't provide further detail.
MY BAD P3067, didn't find it on the service Manuel 8-[
x 6956
I can't get the data on this one sorry.
508c5
x 4
GiveMeABreak wrote: 22 Sep 2022, 12:37 I can't get the data on this one sorry.
thx
