Identifying Your RT3 Unit
c.morewood
- x 55
Re: Identifying Your RT3 Unit
3 days later and stilltrying to install diagbox 7.02.. I managed it once but then got the dreaded "erreur de chargement de cellule " fopr which the only solution I ca forn is upgrade or removal and reinstall.. Which failed on the first attempt
... ongoing
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Vlado
Hello, I installed rt3, Citroen C5 2002 everything works for me except the buttons on com 2000 left for voice and right for trip computer, does anyone know what the problem is
- x 6947
Probably because if you have retro-fitted the RT3, then the existing Comms, module fitted does not support the RT3.
Vlado
The problem is that it used to work, now it doesn't work, I even changed com 2000 and it still doesn't work
IGGY
Hello people looks like i have done the impossible but now i need your help my 2003 C5 didnt have any type of radio only the basic one so i cut the wiring and modified it on my own i have bulit in an RT3 sw5.58 and the best jbl speakers that come in a 00-04 model
Bu ti have a question can i put sw6.63 on my sw5.58 RT3? My RT3 is fully working all options only my fuel consumption dissapeared when i crashed.
- x 6947
No you can't. There were 2 different versions of RT3, Full CAN and CAN VAN versions and the units and software are not interchangeable.
bulkier
Hello,
I am confused with my navigation in Peugeot 308 sw T7:
Based on viewforum.php?f=44 it looks like RT4:
but on sticker it say it is "RT3 T7-N3"
So what kind of Frankenstein I have?
My VIN is VF3**************[VIN obfuscated, can be read by forum staff]
EDIT:
one more information - I can not see Device information (Firmware...) by holding "Menu" button. I only get "Help" menu after holding MENU button for three+ seconds...
EDIT:
- x 6947
Hi, you have an RT4 which is basically an improved RT3, so don't worry about it.
bulkier
Thank you! Now I know in which subforum to post question about it...GiveMeABreak wrote: 03 May 2024, 20:55 Hi, you have an RT4 which is basically an improved RT3, so don't worry about it.
