Here we go again.....
Having watched several Youtube videos and removing the side panel in the passenger footwell, I half expected to see a black box with a filter in it behind said panel.
Nope!
This is what I'm greeted by - not a space anywhere the size of the filter - I'm obviously looking in the wrong place but......where is it?
Your thoughts, suggestions and comments are appreciated
Cheers
2010 C5 cabin/pollen filter
- x 2941
Re: 2010 C5 cabin/pollen filter
Not sure where that is but if the filter is in the same place as the C5 2 it's to the right of the footwell above the transmission tunnel behind the carpeted area and up.
- x 1922
See here viewtopic.php?t=56902
andy_k
- x 17
cheers folks, I'll have a look tomorrow afternoon
andy_k
- x 17
Gibbo2286 wrote: 23 Aug 2022, 18:12 Not sure where that is but if the filter is in the same place as the C5 2 it's to the right of the footwell above the transmission tunnel behind the carpeted area and up.
that's in the passenger footwell - forward of the centre console and above the carpeted area
Ross_K
- x 110
I took some photos when I changed mine a few weeks ago…hope these help:
When you're putting the new filter in, you might find you can make more space by twisting off the pipe that directs air into the footwell (it's up behind the glovebox, to the right of the footwell light). EDIT: You can actually see the grey foam on the end of the pipe in the third and fourth photos above
Also, get a pound shop feather duster to sweep the crap out of the filter box before fitting the new filter
andy_k
- x 17
well, that's a job I don't want to do again
it was a pain to get out, the new one went in a lot easier than expected - only one clip broke so thanks for the screw holes Citroen.
That locating screw for the side panel is a PITA - I'm no lover of small Torx fixings.
Thanks for the help folks
