Hi
Can anyone send me a PDF/photo/link to of the rear brakes and part numbers at all please?
Drum brakes.
1993 (June ‘93) 1.9D 48kw/64hp.
First time I’ve had to buy for drum brakes and want to ensure I get all the parts I need and the correct parts.
Thank you.
1993 Citroen ZX Rear Drum Brake Part Numbers.
99xantia
- x 6945
Re: 1993 Citroen ZX Rear Drum Brake Part Numbers.
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
99xantia
Thank you ever so much. I have just donated.
Do I access things on my own or is it just ask as and when I need anything?
I’d love front and rear suspension and breaks if possible please.
Reason: Removed Previous Post Quote
- x 6945
Ok, so for your vehicle, it could of been fitted with either a Girling or Bendix rear brake system. Which you have, Citroen don't specify, so I will put up both diagrams and you will have to advise which you have and then the item numbers you require:
Both have a 4-shoe pre-fit Brake Kit (15) or (16) depending on which diagram you are looking at.
Bendix Rear Brakes
(1) OEM Brake Plate Left, Part: 421169 (NFP)
(1) OEM Brake Plate Right, Part: 421269 (NFP)
(6) BRAKE HUB AND DRUM, Part: 424732 (NFP)
(7) OEM REAR HUB BEARING, Part: 374817 (NFP)
(7) Cheaper Alternative, Part: 1681935380, £24.17
(15) OEM 4-SHOE PRE-FIT BRAKE KIT, Part: 42415Y (NFP)
(15) Cheaper 4-SHOE PRE-FIT BRAKE KIT, Part: E170063, £92.03
Girling Rear Brakes
(1) OEM Brake Plate Left, Part: 421170 (NFP)
(1) OEM Brake Plate Right, Part: 421270 (NFP)
(16) OEM 4-SHOE PRE-FIT BRAKE KIT, Part: 42414R (NFP)
(16) Cheaper 4-SHOE PRE-FIT BRAKE KIT, Part: E170034, £93.00
Note: (NFP) = No longer Available from Citroen
Bendix Rear Brakes
Girling Rear Brakes
99xantia
apologies, I did just notice the part number request thread at the top of the page, will use in future!
I haven't yet got to getting the rear wheels off but I know the front are Girling callipers. I will add a photo if this helps identify? I appreciate it's from the back...
- x 6945
Ok, I can't help you identify the make, but I've updated my last post with the main part numbers of the kits for both. You will note the hub bearing is the same for both. I've included the parts for the items no longer available from Citroen (NFP) so that you can still search elsewhere on the part numbers. Autodoc have some of these parts.
99xantia
Thank you ever so much that’s great.
- x 1489
I recall you can tell from the shape of the cylinder poking through the back plate - Bendix appears to be round, Girling oval.
- x 6945
Cheers Richard - I'll have to remember this for later ref.
