DS5 no ignition key not detected
Cruiser786
Hey guys I have a citroen DS5 style 2.0 hdi manual 2014 ,when keys inserted into key reader I push the start button & i get no response no ignition nothing the remote locks the doors but nothing on the speedo not even a key not recognised or any lights what so ever.
Check pic for fault codes picked up ,any ideas would be appreciated ,I've checked all the fuses changed the key reader and alarm ecu module I havnt changed the adml cemo bml ecu relay module.
- x 6955
Re: DS5 no ignition key not detected
Unfortunately, you seem to be missing some of the fault code. There is usually another 2 numbers on the end which provide more information as to which system or sub-component is faulty. Your diagnostic kit may not be able to read the codes.
The only vague information I have is a supply fault to the reader:
B100C 1C Electronic steering lock supply fault. This means there is a supply fault, so it is not going to work, so won't recognise the fob.
U1F00 00 Event not recorded fault. This means the BSI has not received specific information from the ECU that recorded a fault, so it can't tell you anything else.
So needs further investigation as to where the supply fault is.
The first thing I would check is Fuse F9 in the engine fuse box. Then check Fuse F8 in the BSI.
These may help with checking your wiring connections...
Electronic Steering Lock
AE00: electric steering lock
PSF1: engine compartment fusebox panel
BSI1: BSI
Electronic Key Reader
8239: hands-free access and starting electronic key reader
8235: engine starting switch
BSI1: BSI
Cruiser786
Thanks bro appreciate your time and diagrams i think I have another screen shot of the codes what you think of these ,I will try and get a different diagnostics on the car and report back with the codes
Cruiser786
Seems like I have no communication with electronic key reader ,alarm ecu and hands free kit ecu which i have tried 2nd hand units but to no avail
- x 6955
I have a little more info on a couple of those faults:
If you haven't changed any configuration with your diagnostic tool in the BSI or elsewhere, then there may be an issue with the low speed CAN data network.
| Fault Code: | U1F35 87 |
| Description of Fault: | _absence of communication with the electronic key reader. Absence of communication with the electronic key reader (For 2 seconds). |
| Conditions for Fault to clear: | Communication with the electronic key reader (For 2 seconds). |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U1F30 87 |
| Description of Fault: | _absence of communication with the hands-free unit. Absence of communication with the hands-free control unit (For 2 seconds). |
| Conditions for Fault to clear: | Communication with the hands-free control unit (For 2 seconds). |
| Downgrade Modes whilst Fault is active: | Hands-free remote control present in the electronic key reader - Starting possible if the vehicle has not got a hybrid drive chain - Activation of the power unit if the vehicle has a hybrid drive chain |
| Symptoms: |
| Suspect Areas: |
Cruiser786
Thanks Marc you're very helpful, ok so is the ADML unit located behind the BSI the hands free unit?
- x 1431
Have you checked for power and earth at the key reader?
- x 6955
Hands Free Reader ADML Location Although this shows left hand drive it will be in the same place - inside the passenger glove box near the BSI somewhere.Cruiser786 wrote: 27 Jul 2022, 11:42 Thanks Marc you're very helpful, ok so is the ADML unit located behind the BSI the hands free unit?
Cruiser786
Right so I have already replaced the key reader im assuming its not configured and is plug n play this made no difference & yes the ADML unit is behind the BSI.
There is a live/earth feed coming to all the modules.
Marc do you know if the DS5 should display key not detected on the dashboard as I get nothing ,pressing the start button only wakes the BSI up & the park brake light illuminates on the dash this happens with out the key even there
- x 6955
It's not plug and play as such, the following parameters need configuring or checking that they are correct as shown below. All values with (2) must not be changed and must reflect what is shown in the table on this vehicle.
So once you have confirmed that the unit is the correct part number for the vehicle and that the parameters are correct, you do need to make sure the earth and power are there as Richard mentioned and as detaile dinthe fault code list I put up as possible symptoms.
| Configuration parameters | Valued to be configured | Comments |
| Maintained press function | Function activated | (2) |
| Hands-free presence of the rear door handles | Unlocking and locking | (2) |
| Hands-free presence of the front left door handle | Unlocking and locking | (2) |
| Hands-free presence of the front right door handle | Unlocking and locking | (2) |
| Presence of a boot unlocking control | absent | (2) |
| Presence of driver selectivity | Function present | (2) |
| Presence of the boot internal aerial | Aerial present | (2) |
| Presence of the boot external aerial | Aerial present | (2) |
| Type of child safety | Electric child safety | (2) |
Cruiser786
Thanks Marc cant thank you enough for your help im gona get my local indy to hook is peugeot planet up & report back thanks dude your awesome
- x 6955
He'll need Diagbox for this vehicle (PP2000 is for Peugeot and Lexia is the older software for vehicles around 2007/8 and earlier). If he has Diagbox, then it will launch the correct software automatically.
Cruiser786
Hes told me his diagnostics isn't working properly needs a week or 2 so I've ordered a diagbox myself will have a little mess around with it see if I can pick up on anything ,strange thing I've noticed the hazard lights don't flash when I lock/unlock the doors with the remote & the red led on the start button is illuminated dim where as i saw on another car it was quite bright beginning to think there may be a wiring issue
Cruiser786
Hey marc got some good news cars up and running again I stripped everything down used you're wiring diagram couldn't find anything suspect re checked all the fuses & lo & behold 1 fuse in the bsi was blown ,thanks for taking the time with your posts really appreciate it
- x 6955
Well done on finding that - saved a few quid! - and thanks for the update.
