Front windscreen c5 x7
davoxx
- x 15
So I got my front windscreen changed on my C5 X7, and I swear the new screen is brighter.
Was there a tinted version of the front screen on the exclusive?
The windscreen glass company says they are all the same, and that it's because the glass is new and clean it looks brighter.
Am I crazy or are the front screens slightly tinted?
why?
- x 6955
Re: Front windscreen c5 x7
Yes the front screens are tinted.
The only difference is that there were versions without a rain sensor and one with the 16 speed rain sensor before 30th Nov 2009.
Both also had different screens for later models 30th November 2009 onwards as above without or with the sensor.
davoxx
- x 15
So could the replacement one be less tinted compared to the original Citroen one or just a cheapo after-market with no tint?
why?
- x 6955
You won't get an original Citroen replacement unless you order it directly from Citroen (Saint-Gobain Sekurit), in which case the insurance company (if using them) will either refuse to pay for it outright or may provide a portion of the cost up to what they would pay from the glass company.
It will be made by one of the usual glass companies. They are supposed to be identical in specifications, but I've also noticed differences too when I had my X7 one replaced. More concerning though is the light / rains sensor. I warned them about making sure they did the job properly - but sure enough after they completed it, the gel pack went opaque where it was removed and replaced, causing poor performance.
I complained and they came back out - same fitter with his water bottle spray. I told him that's not good, as it has 16 levels of detection and he almost had to poor the water on for it to operate.
Gave them the official part number and they coughed up for a new one - circa £250! Covered by their insurance.
- x 6955
Actually it's now gone up to £292.24 for the replacement sensor.
davoxx
- x 15
Read your post.
Great, the car is an 09, with rain sensor and I can see the air bubbles!
Will now have to figure check if it is working correctly
Cowboys ted, they didn't even change all the side trim clips, as they now try to reuse as many as possible.
why?
- x 6955
That is essential when replacing the trim as it's a safety factor that holds the trim in place. If they have not done this - complain and get them to do it as it is a manufacturer recommendation.
Your sensor will have weakened performance guaranteed. It has 16 adjustable speed levels to meet all conditions, and you may find that the sensitivity has diminished greatly as a result, resulting in less wiping of fine rain and also poorer light detection.
Personally, I just can't abide sloppy work. The repairs are guaranteed. If you are not happy, make a complaint and stand your ground. They have insurance to cover things like the sensor. But unforgiveable regarding the clips as this is a safety issue and they must be replaced. The fitters on all my replacement windscreens always replaced with new clips.
If this is on your car insurance, then make a complaint to the car insurer and they will get in touch with the windscreen company - after all you have to use their recommended ones in most cases, so they need to come down hard on them if they are cutting corners. Just throw 'health and safety' at them and they'll soon start shifting.
H4wkeye
- x 14
Are the actual sensors embedded into the windscreen or? I've seen used windscreens with the sensors still visible.
- x 6955
No the sensor is a separate unit that clips into a holder on the windscreen. The sensor has a ribbon connector to the ceiling console above the rear view mirror.
Breakers are not too picky and will just rip out components without much care. They won’t be necessarily bothered with taking trim to pieces to unplug connectors and the like, so probably just cut the wiring,
H4wkeye
- x 14
Ah I see. I had my windscreen replaced by the previous owner, however he opted for a used one off a Citroen, since they only offered 3rd party ones otherwise. Though the sensors seem to work fine, light and rain.
- x 6955
If the sensor has remained clipped into the windscreen housing, so it can be plugged back into the wiring, then there is no reason why it should not function correctly - the problems start when the sensor is physically removed from the windscreen housing, where the gel pack can become cloudy and opaque as air gets in and it becomes distorted from pulling it off.
H4wkeye
- x 14
Oooh I see! That makes sense.
davoxx
- x 15
Yeah, so it rained, and the wipers were slow to start and kept going for a while when the rain stopped.
I'll give them a call and get the sensor issue fixed.
I spoke to the guy about the clips when he fitted them he replaced 4 broken ones, but he said that they said it's okay to reuse?
So I'll ask them to replace all of them as that's the proper way right?
It is on my insurance, but the insurance companies in Ireland are c*nts and there is no one to complain to as the ombudsman is always on their side.
why?
- x 6955
It's a safety issue and if they are supposed to be replacing the windscreen then it should be to the manufacturer's own safety standards. See below in Red:
Click Image to Zoom
Click Image to Zoom
davoxx
- x 15
