Where have all the xantia posts gone?
ksanturion10
- x 19
Re: Where have all the xantia posts gone?
I can fill a whole blog about all the stuff I've changed and found
(and that still have to be repaired) , but unfortunately I like to drive it, so... think to just enjoy it for now
Only himself the stupid makes wrong, many are being confused by the clever
jauv
- x 12
Thanks! Asked the local Cit shop by mail, they didn't answer. But I'll just visit them when I get to make time - welding job is scheduled for next week.white exec wrote: 19 Aug 2020, 17:18 The sill bung (blanking plug) is still available from Citroen, under that pt.no. 96 130 325.
Any Cit/Peu parts counter should be able to supply.
However, today it was raining and I noticed an LHM leak. Not quite sure of the exact location, I only got to look at it alone (I suspect turning to lock might make it leak). Otherwise it's dripping a drop every few seconds. Took some quick photos in the rain but couldn't find a definite location of the leak.
Looks suspect
Lower hose is wet
Welp, at least it's fairly green
Temptation to run away from this car is at all time high
Reason: Inline images
admiral51
- (Donor 2026)
- x 391
You need to get the excess cleaned up so you can then see where it is really leaking from, it does spray everywhere and looks way worse than it probably is.jauv wrote: 03 Sep 2020, 17:40Thanks! Asked the local Cit shop by mail, they didn't answer. But I'll just visit them when I get to make time - welding job is scheduled for next week.white exec wrote: 19 Aug 2020, 17:18 The sill bung (blanking plug) is still available from Citroen, under that pt.no. 96 130 325.
However, today it was raining and I noticed an LHM leak. Not quite sure of the exact location, I only got to look at it alone (I suspect turning to lock might make it leak). Otherwise it's dripping a drop every few seconds. Took some quick photos in the rain but couldn't find a definite location of the leak.![]()
Looks suspect
Lower hose is wet
Temptation to run away from this car is at all time high![]()
I have read back and it is a car that was sat up for 10 years so expect a few issues as the system gets used to being used again, if it is dripping every few seconds maybe a seal fingers crossed
- x 1751
No running away! (Forum Rule number 99)
A slow leak can often be a low-pressure return pipe (rather than a high pressure one, which will usually leak faster). Looks like it's coming from above/high up, and dripping down on the subframe. Might even be up near the reservoir. The rubber elbows/joiners on the return pipes (eg those on the height correctors) can split, perish, or come loose.
Someone here will know Xantia pipework better than I do, so could interpret your photos better.
jauv
- x 12
Thanks for the pointers and encouragement, on a more serious note I won't run without knowing exactly what's wrong and the cost to repair. I do love the car after all.
But timing is a bit unfortunate, as I've got an extended weekend trip coming up starting tomorrow, right after work. Managed to arrange an egg-shaped loaner car (Xsara Picasso) but this means Xantia has to wait. Well, it's better than blowing the seal (or whichever component responsible) during the trip.
And indeed, the car has lots of old rubber.
jauv
- x 12
Well, the MOT failing rust is no more!
(Inside was of course done as well but fumbled the phone while attempting to picture those...)
Missing blanking plug was replaced with a tac'd on sheet of metal and chassis coating - might be a mistake but couldn't figure out a reason to access that compartment.
But the leak isn't fixed - but source is one of the lines going into the power steering rack, according to a local shop. Also a sweaty drive shaft bushing was identified. I'm on the lookout for a local shop who knows their way around Xantias.
I suppose I should make my own thread for this particular vehicle to avoid taking over this one.
admiral51
- (Donor 2026)
- x 391
Repair looks well done, actually very well done
Yes make a thread in the members area Blogs and Galleries trust me it will run and run lol
jauv
- x 12
Going to continue there once I have actual updates - meanwhile, I think the Xantia looks mighty fine this morning.admiral51 wrote: 15 Sep 2020, 18:51 Repair looks well done, actually very well done
superloopy
- x 19
Well, it's been a while since I asked the question and today has been a decent day up here in the northeast, so good that I gave my 'resting' activa a scrub up. She didn't come up that well, the lacquer (Dante red) has moreorless lifted everywhere and it crossed my mind ... should I bother or get rid? That lasted for all of a minute and I spent the rest of the afternoon dragging all of my tools into a known place ready to make a start on fixing her leak. Question is, she's been standing a number of years, what is the routine for bringing her out of hibernation? Will the engine be seized, how do I check? I assume if not then a quick oil change, followed by a turnover and if successful an lhm top up, there's not much in there after the original leak. Any advice on bringing her to life again appreciated ... cheers.
Mike
Skull
- (Donor 2026)
- x 379
Well I'm down to just one Xantia now and I've got it in for MOT on Tuesday
Mike if you're worried about the engine being seized up - remove the spark plugs and spray a little oil in there, then either put it in gear and rock the car a little and watch the crankshaft pulley rotate / or out of gear, socket on crankshaft pulley and try to rotate the pulley clockwise thus turning the engine over ...
If all seems well with the engine then get the pipe/hose/leaks sorted if you know where they are ....if you don't know where the leaks are add some fluid (old lhm will do initially) run the engine and observe ...get them leaks fixed then you can clean out the LHM tank add new LHM+ and bleed through the brake lines / turn the steering wheel lock to lock a couple of times ....if all is well the old fluid will be bled out ...nice green LHM+ will come out the brake lines, close the bleed nipples and
Gary
Gary
Skull
- (Donor 2026)
- x 379
Gary
Gary
Gildas
- x 6
Another one makes it back onto the road.
My 2.0 petrol auto is back. It has been off the road for over a year and a half.
I bought it with an expired MOT and it has taken a lot more work than I thought it would to get it roadworthy
I have changed the auto box fluid cooler and the strut mounts. I had no idea that these were weak points when I bought the car.
Have fitted comfort spheres on the front have the rears to do.
Its still on the original cambelt but I think I will take it up to Wolsey House to do that plus at least one high pressure pipe needs replacing.
Best wishes
RW
Best wishes
RW
- x 6957
Just for info, there were 537 Licensed Xantias on the road in the UK at the end of the first quarter in 2022, and 2128 on SORN.
I was just looking at some data for another member, so thought you all might be interested on the Xantia situation.
- x 16
Well... there's a Xantia 1.9D n/a engine, simple suspension, no airbags. Every single pipe union is open-ended spanner free. The gearbox shifts like new. Over twenty oil & filter changes from new in its genuine 50k miles life and only 38 k six years ago. Six oil changes since then...
The interior is very good. Needs a n/s/r wing repair and paint. The engine last ran the week before the lockdown. Dark metallic green. The engine started 2nd glow-plug cycle last week. After she started, she so very nearly went for scrap...
No corrosion on the front door hinge areas. Anybody fancy taking her on?
IT'S MINE!!!
I still plan to restore her back to new, but I have to make my unit pay and old Citroen Xantia are not the way...
Any interest and I will list it for sale. The 'hen's teeth' front height corrector to anti-roll bar is nearly new. Never been welded. Sat in an Edinburgh showroom as a display exhibit (really) for years. My renal failure and kidney stents saw me use a more practical (?) BMW E36 Touring as my daily driver, also for sale. Anybody wants to save it?
Runs/drives. You can legally tow it despite what the experts say. We towed it eight miles a few weeks ago with the BMW...
Might be gone by end of May. Serious interest and I will sell. I'm doing a Suzuki 4x4 brake pipe job on Thursday. If it makes me cross, she will go for SCRAP. Sorry Green CAR.
IT'S MINE!!!
- x 1459
It might be a good idea to make a post in the sale/wanted section of the forum. If you really need to trid of the car, I would suggest advertising it elsewhere for a wider audience.
