Upper ball joint stuck - Citroen C5 X7
cedrichn
Unread post by cedrichn »
Hello! Happy Easter!
Like some I guess, I used this long weekend to refresh the suspension on my C5 X7.
Surprisingly, the lower ball joint was easy to replace, but the upper one is completely stuck... I do have the good socket, tried with a 1 meter extension...and it even broke my extension! Any advise ? I am thinking of buying a powerful impact driver, or buying a complete "arm/pivot" from breaker...
Thanks!
Stewart(oily)
x 35
Re: Upper ball joint stuck - Citroen C5 X7
Unread post by Stewart(oily) »
Heat the thing up with a hot air gun or blowlamp,or borrow a good impact wrench for a few minutes, I borrowed a large milwaukee one from a mate that can loosen 35mm hub nuts in a trice, in extremis I have resorted to cutting the old balljoint to pieces and using a stillson on the last bits, though that was the act of a desperate man. good luck.
x 1506
Heat...but that is an aluminium carrier, I'd say 50/50 at best the threads will not come out with it. I recall someone having that trouble with a C6 joint and having to replace the carrier.
cedrichn
Thanks for the feedbacks. Already tried heat, and made no difference....
I am now thinking of buying an impact gun/driver, but spending around £80 for a second one if it makes no difference will be a bit more annoying...
I am having a look at breakers around me now :D
I will not do the upper one on the other side :/
davoxx
x 15
Unread post by davoxx »
I think there is a specific spray that will break down that corrosion, you spray it and leave it for a few hours and with an impact gun it should come off.
why?
KennyW
x 165
Unread post by KennyW »
When I did mine I removed the strut assembly and fitted in vice.
Followed by heat penetrating fluid and breaker bar and 6 ft scaffolding pole.
Keep heating , spraying and applying steady pressure with breakerbar and extension it eventually broke the seal but was very dry with Aluminium oxide. Once moving I moved ball joint back and forward to help it off
C3 1.4 petrol (SWMBO)
cedrichn
Finnally got it!! Such a hard thing to do ... I think what helped me was to cut the ball joint short, so the heat could reach the thread better.
Now, I feel like the screw going through the pivot holder, at the top, can move... The bushes are not holding the screw tight into the pivot holder:is it normal? Doesn't feel like, but I can't see any part worn... As I am there, I would like to be sure before reinstalling everything :D
Thanks!
