Picasso 2004 turbo cover part number
bighairybloke
(Donor 2022)
x 7
Unread post by bighairybloke »
Hi, this new to me Picasso has a loose turbo heat shield. It’s a 1.6hdi 110 motor. Can anyone help with a. Part number pls?
Cheers
Steve
x 6957
Re: Picasso 2004 turbo cover part number
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
bighairybloke
(Donor 2022)
x 7
Happy to make a donation and have just done so.
Cheers
steve
bighairybloke
(Donor 2022)
x 7
VIN VF7**************[VIN obfuscated, can be read by forum staff]
x 6957
Thanks for your donation Steve.
Please provide the VIN in full for me as this part is no good. It will be automatically masked when you submit your post, but staff will be able to see it.
bighairybloke
(Donor 2022)
x 7
x 6957
Steve, have a look at this top diagram showing the exhaust system heat shields. Let me know the item number:
Here is the Turbo for reference with the above:
bighairybloke
(Donor 2022)
x 7
This piece seems to be missing it’s mounting tabs. The whole thing moves.
Here’s a YouTube link
x 6957
Ok, so I think the part is item (1). It's hard to see, but it's the Manifold Heat Shield, part: 1723T3. The cover (1) goes over the turbo and is fixed using washers (14), Part: 1712C9, item (70) CBLX RDL Screws, Part: 691272 and item (71) Flanged Screw, Part: 6925G5.
I hope this helps.
Here's a picture of the whole thing:
As this part attaches to the other heat shield around the DPF / Cat (2), it can look to be one part, but it's not.
bighairybloke
(Donor 2022)
x 7
Thanks for that, are there any mountings lower down?
x 6957
The only one I can see is on the other half of the heat shield, item (3), which would also take an item (70) CBLX RDL Screw, Part: 691272
bighairybloke
(Donor 2022)
x 7
Fab thanks.
Also, does this car have a DPF ?
x 6957
Not on your model for this year Steve. That only came in on later 1.6 110 HDi PSA vehicles, so yours just has the CAT, no DPF.
bighairybloke
(Donor 2022)
x 7
GiveMeABreak wrote: 18 Mar 2022, 18:59 Not on your model for this year Steve. That only came in on later 1.6 110 HDi PSA vehicles, so yours just has the CAT, no DPF.
Ah, i thought mine was the 110 engine. That’s a relief…I think. There is a fault ‘polution’ which occasionally comes up the previous owner said. I’d assumeD it was the DPF. Will know more with the lexia….
x 6957
You do have the 110 engine, just without the DPF as that was not fitted until later. You have the 110 Bhp DV6TED4 engine without FAP (Particle Filter). So just make sure they are aware of that at MOT! They should be though....
