Citroen C3 RH drive shaft part number
Nego2403
I'm looking for a part number for the right drive shaft for a Citroën C3 with VIN number VF7**************[VIN obfuscated, can be read by forum staff].
Is it possible to pull the driveshaft directly out of the gearbox or is it secured in some way?
The reason I'm asking is that I don't see any hanger bearing.
- x 6955
Re: Citroen C3 RH drive shaft part number
For official part numbers and parts diagrams, please see below:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this by Stellantis. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
Nego2403
I understand that. I've made a donation
- x 6955
Ok, so here you go:
Item (2) Drive Shaft Right
Citroen OEM, part: 9816028680, £401.40
Citroen Exchange Driveshaft, part: 1622959880, £234.06
Prices include UK VAT (20%) and correct as of today, available directly from Citroen. Note there is an additional refundable surcharge of £133.92 on return of the original driveshaft.
I'll put you up a guide in the resources section shortly on replacing it, then provide you a link in htis post when I've done it.
- x 6955
Nego2403
Thank you very much for the information!
Nego2403
I've been changing the drive shaft and the new shaft doesn't look like the old. On my car it looks like the drive shaft on the right side of the car doesn't have a support bearing outside of the gearbox.
The drive shaft looks the same on both sides. The only difference is that the right drive shaft is a little bit longer.
- x 6955
They are different parts for the right and left drive shaft. I only provided the one you asked for (right side), so if you need the left drive shaft part number, let me know.
Nego2403
The eccentric bolt heads are not present on my car. The driveshaft is going directly into the gearbox without any bearing in between. It looks like the bearing is just inside the gearbox. I've checked a parts supplier for the driveshaft and there's two types of driveshafts listed for my car.GiveMeABreak wrote: 12 Apr 2022, 10:51 They are different parts for the right and left drive shaft. I only provided the one you asked for (right side), so if you need the left drive shaft part number, let me know.![]()
The first one is the same as the one in the diagram where the eccentric bolts are mentioned. (which is not on my car): The second one is shorter and the bearing is also closer to the gearbox(looks like the one on my car): I'm not sure which of these is the right one. Other than this, is the repair manual in general for the DV6FD engine or is it specifically for the C3?
- x 6955
Unfortunately I can only help you official Citroen parts, as aftermarket suppliers can be notoriously bad or the wrong type, depending where you source them from. I put the guide up above for you, so everything you need should be listed there including the lip seals.
Nego2403
That is understandable. But it's weird for me, when I search the part number you've provided the driveshaft that comes up is much shorter than the one on the diagram. Is the diagram wrong? When I look under my car I don't have the part #12 which is holding the bearing.
- x 6955
Make sure you are not getting your right and left mixed up!
Left and right sides are determined as you are sitting in the driver's seat. So as per the diagram (2) the right hand driveshaft is longer than the left hand driveshaft (1).
The nuts (8, 9 & 10) are separate parts.
Nego2403
Yes I understand thatGiveMeABreak wrote: 12 Apr 2022, 14:16 Make sure you are not getting your right and left mixed up!
In my case there is no such thing and the axle pulls straight out. It is much shorter and looks like the one on the picture I posted above. The reason I'm asking this is because I'm unsure if I need to release some bolts before removing the driveshaft or if the eccentric bolts are built into the gearbox and not visible from underneath.
If you see this link: https://www.b-parts.com/da/store/produc ... 8680-2012/
You can see that the part number doesn't match with the diagram. The drive shaft on the diagram is not the same.
- x 1485
Can you take a photo from underneath and post it up?
Is it a 1.6 diesel you are dealing with?
Nego2403
Yes I can. I will be working on the car in a couple of weeks. I will be posting pictures when I get under the car again. Yes the engine is a 1.6 BlueHdi 100.RichardW wrote: 12 Apr 2022, 15:36 Can you take a photo from underneath and post it up?
