207 1.6hdi, About to replace Eolys Pouch, and DPF filter, advice please.
avamotor
(Donor 2022)
Unread post by avamotor »
Hello French Car Forum,
Follow a recent journey The message "risk of filter blockage" appeared on the multifunction display screen. I nursed the car (Peugeot 207 1.6 hdi 90 9HP) home and read the error codes these being:-
BSI fault reading
F5FF Unexpected re-initialsation fault coming from the BSI
Characterisation of the fault: Not characterised
EDC17C10
Principle relay control
P0215
Status: temporary fault
Characterisation of the fault: poor operation of the relay A
And
P1490
Characterisation of the fault: detected overloaded
Whilst looking through various menus including "Exhaust line information" I also have notrd the odd temperature of 149 degrees particle emission filter upstream temperature, when a few posts have made reference too so I will check the resistance and see if there is any change with a heat gun.
I last cleaned the DPF in March 2019 and refilled the fap at the same time and I inherited the car later that year and it has been fairly reliable.
To save any messing around with dpf cleaner etc this time, I have purchased a new BSM, dpf, sealing ring/clamp and a brand new pouch of Eolys powerflex (9678033680).
This may sound like a silly question but in the "throat" of the connector from the bag of Eolys, there looks to be a bung/stopper that stops any fluid leaking out during transit. Does this remain in the connector and I just fit the bag in or am I supposed to retrieve it?
Still trying to find the procedure from my notes in getting to pack repair, replacements parts etc but will track them down.
BSM fitted today to try and remove some electrical gremlins, checked and cleaned cables and fuses and all apears well regarding that.
Any advice would be appreciated to save me damaging anything I shouldnt!
x 6960
Re: 207 1.6hdi, About to replace Eolys Pouch, and DPF filter, advice please.
It should just fit into the 'click-fit' connector when you fit it back into the additive support unit.
avamotor
(Donor 2022)
Thank you Marc. Hopefully it will all go smoothly.
alexvalcic
x 3
Unread post by alexvalcic »
Did you do an additive level reset and counter reset when you added Eolys? What is the Differential pressure in driving and idling?
Reason: Removed YouTube Link (Unavailable Video)
avamotor
(Donor 2022)
Hi Alexvalcic,
Yes changed the info where required, it knows its been refilled and dpf replaced.
Before change DPF, Difference in pressure between particulate emission filter input/output 014 mbars at 854 rpm.
After changing dpf,
Difference in pressure between particulate emission input/output rpm after swap now at 001 mbars at 875 rpm.
Weather been too poor to test it on the open road.
avamotor
(Donor 2022)
Has anyone ever had the lower dpf pressure pipe bolt seize up inside the fitting and did anyone managed to remove it without damage to the dpf? Please could I ask how you managed it.
I have so far tried butane gas torch, followed by wd 40, the 19mm spanner i thought was turning it only to find its rounding it. Mole grip not doing anything and I really dont want to damage the old dpf.
Helpful advice gratefully recieved
avamotor
(Donor 2022)
**Solved and sorted** car running okay, no errors any longer, managed to weld metal to nut of dpf pipe and remove successfully from the car.
Paulahounslow
New User
Unread post by Paulahounslow »
Hi, I have dpf fluid low, I need to replace but not sure which fluid I have to get, can I check with VIN?
x 6960
Yes, pop your VIN up here (it will be automasked on post submission) and I can advise which type you need.
shizzle
(Donor 2022)
Unread post by shizzle »
hi Marc,
similar issue to the previous poster. I'm looking for the correct DPF refill pouch part number for a 2011 Peugeot 207 1.6hdi 92bhp. vin:
cheers,
mike
x 6960
Hi Mike
You need a Powerflex additive pouch for your vehicle. You should be able to find plenty of online suppliers, but make sure it is only the 1.1 litre size, not the 3 litre.
If you require official part numbers, please see below:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
shizzle
(Donor 2022)
hi Marc,
many thanks for the quick response.
I've updated my membership.
I've found lots of different sizes all listed as compatible on various suppliers.
do you have a definitive compatible part number list?
cheers,
mike
x 6960
Hi Mike
Thanks for your Forum Donation.
Item (15) Flexible Additive Pouch, (Powerflex), part: 9678033680, £175.06 inc. VAT direct from Peugeot, or you can search on this part number on the web for possible cheaper sources, but be aware you will also need to reset the additive counter with a professional level diagnostic tool like Diagbox.
shizzle
(Donor 2022)
many thanks!
mike
shizzle
(Donor 2022)
sorry to be a pain;
have replaced the physical pouch but I'm getting the following errors in diagbox:
P1445 - The quantity of additive injected into Particle Emission filter has exceeded the maximum threshold. PEF must be changed.
P15B3 - calculated additive level below the critical threshold.
my diagbox (9.91) isn't allowing me to reset those faults.
any suggestions?
cheers,
mike
