C5 X7 Emissions
osx
(Donor 2022)
x 15
C5 X7 Emissions
Unread post by osx »
Failed MOT because of emissions (0.5 cutoff, 1.2 measured with engine temp at 85C). Had new diesel filter fitted last month and using additive in every tank so expected everything to be fine as engine running fine and 90% of the time the C5 is on the motorway. Any point cleaning the EGR?
C5 X7 Exclusive 2.0 HDi Auto
x 6955
Re: C5 X7 Emissions
What sort of additive are you putting in? Citroen expressly tell you not to put any additives in the tank, so I'm curious as to what it is you are putting in, as this may have a detrimental effect if mixed with the DPF additive that is also injected from the additive tank when adding fuel.
osx
(Donor 2022)
x 15
Re: C5 X7 Emissions
Redex diesel system cleaner. Been using it for years and have topped up EOLYS twice during this period.
https://www.amazon.co.uk/Redex-RDX06EF- ... B00E5DEQBW
What is the part number for the EGR as I would rather replace it
x 6955
Re: C5 X7 Emissions
Your donor subscription for parts has expired now :wink: - it lasts for up to 2 years, so links below if you want to renew, as we also in turn have to renew annually.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
osx
(Donor 2022)
x 15
Re: C5 X7 Emissions
Time flies indeed. Have renewed my membership.
Managed to remove 6 screws from the EGR but there must be more underneath as it doesn't budge. Can I still remove it without having to go under the car?
I believe it is an Allen bolt - is this actually needed as there are more than enough screws to secure the EGR and some models with the same engine and EGR don't have it.
Steve Walsh
x 515
Re: C5 X7 Emissions
Unread post by Steve Walsh »
The Allen screw is underneath the EGR. you need a 5mm allen key, it screws upwards into EGR and needs a couple of turns to enable it to slide out of its slot. It is accessed from the top.
When looking into engine bay from front of car, the allen screw is bellow the screw hole nearest the elec plug
osx
(Donor 2022)
x 15
Re: C5 X7 Emissions
Thanks Steve. If I manage to remove it I don't think I will be putting it back!
Steve Walsh
x 515
Re: C5 X7 Emissions
That crossed my mind but I have OCD about stuff and it would be on my mind if I left it out, My new glow plugs are due here tomorrow so planning on refitting it all.
When I figured where it was and the size it wasn't too bad to do
x 6955
Re: C5 X7 Emissions
osx wrote: 28 Jan 2022, 14:08 Redex diesel system cleaner. Been using it for years and have topped up EOLYS twice during this period.
Can you confirm the VIN please, as you have 2 X7s in your profile, then I can get the part for you. Thanks for membership renewal :wink:
osx
(Donor 2022)
x 15
Re: C5 X7 Emissions
It's the manual X7 only now - VF7**************[VIN obfuscated, can be read by forum staff]
x 1056
Re: C5 X7 Emissions
Unread post by wheeler »
1618GZ for a new one £280.94 + vat
1638155180 for an exhange one £173.61 + vat
There is a £40 surcharge on these too till your old one is returned.
x 6955
Re: C5 X7 Emissions
OK, so:
OEM Original EGR Valve item (1): 1618GZ, £337.13
Citroen Standard Exchange EGR (Delphi): 1638155180, £208.33
All VAT Inclusive as of today
Steve Walsh
x 515
Re: C5 X7 Emissions
https://www.oscaro.com/vanne-egr-delphi ... 7QU4dqxZv2
139.90 on Oscaro, I am sure other vendors stock the same
osx
(Donor 2022)
x 15
Re: C5 X7 Emissions
https://www.ebay.co.uk/itm/144380516243 ... ondition=3
Looks identical but price suspiciously low.
Steve Walsh
x 515
Re: C5 X7 Emissions
It hasn't got DELPHI embossed on casting
