C5 X7 alternator
AndySmiff
C5 X7 alternator
Unread post by AndySmiff »
Hi all,
Does anybody know how to find out the model of the alternator without removing it ? Is it possible from the VIN ? I want to get one on ebay to fit but want to do a straight swap when I take the original off replace it straight away so I need the replacement in advance. It is for a 2008 c5 x7 tourer estate auto. Any help would be appreciated.
Thanks.
x 6945
Re: C5 X7 alternator
We can supply official parts information, but if you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
You may find that there are several options fitted, but we can provide the official part number for you to match an aftermarket one against.
x 1055
Unread post by wheeler »
You can usually see the manufacturers label on the alternator without removing it although often requires a torch & mirror, it’s usually on the plastic end casing & may need a clean up to read it.
AndySmiff
wheeler wrote: 05 Jan 2022, 09:53 You can usually see the manufacturers label on the alternator without removing it although often requires a torch & mirror, it’s usually on the plastic end casing & may need a clean up to read it.
Thanks Wheeler, I'll give this a try on the weekend !!
